I am using torizoncore-builder to build an image which has some minor customizations. Typically in our application we don’t use a display so most of my development and use has been without a display. I was suprised to find that the HDMI output doesnt work using my custom torizoncore image. but hdmi works fine during tezi or stock torizoncore build.
below is my tcbbuild file. its mainly stock with minor changes.
# >> NOTES:
# >> Lines containing ">>" are simply comments explaining the properties that
# >> follow; if you don't like these comments run:
# >> $ grep -v '>>' tcbuild.yaml > tcbuild-clean.yaml
# >> A line not containing ">>" can be uncommented (by removing the hash mark
# >> plus a space from its beginning); also set the corresponding property to
# >> appropriate values.
# >> When uncommenting a line having a property, remember to uncomment all its
# >> parent properties as well; for example: if you uncomment the
# >> 'splash-screen' property, also uncomment its parent property called
# >> 'customization'.
# >> The input section specifies the image to be taken as the base for the
# >> customization.
input:
easy-installer:
# >> Choose one of the options (REQUIRED):
# >> (1) Image as local folder or tarball.
local: torizon-core-docker-apalis-imx8-Tezi_5.5.0+build.11.tar
# >> (2) Remote file (optionally with a filename and or a sha256 checksum):
# remote: "https://artifacts.toradex.com/.../torizon-core-docker-apalis-imx8-Tezi_5.1.0%2Bbuild.1.tar"
# remote: "https://artifacts.toradex.com/.../torizon-core-docker-colibri-imx6-Tezi_5.0.0-devel-202009%2Bbuild.2.tar;filename=torizon-core-docker-colibri-imx6-Tezi_5.0.0-devel-202009+build.2.tar;sha256sum=368595fa3fb00af9604e70311de3b04df6b30b280deec2f8918c46f479026ddb"
# >> (3) Image specification (URL will be generated by the tool)
# toradex-feed:
# version: "5.3.0"
# release: quarterly
# machine: colibri-imx7-emmc
# distro: torizon-upstream
# variant: torizon-core-docker
# build-number: "1"
# # build-date: "20210408"
# >> The customization section defines the modifications to be applied to get
# >> the desired output image.
customization:
# >> Splash screen:
splash-screen: wtr_splash.png
# >> Directories overlayed to the base OSTree
filesystem:
- changes_20220310/
device-tree:
# >> Directories where to look for include files.
include-dirs:
- device-trees/include/
# >> Custom device tree source:
# custom: device-trees/dts-arm32/imx6ull-colibri-eval-v3.dts
# >> Device-tree overlays configuration:
overlays:
# >> Whether to ignore all overlays from the base image (or ostree
# >> archive in the future).
# clear: false
# >> Specific overlays not to use from base image (useful only when
# >> clear is false and not DT has been selected).
# remove:
# - apalis-imx8_hdmi_overlay.dtbo
# >> Overlays to add to output image.
add:
- device-trees/overlays/apalis-imx8_pcie_disable.dts
# kernel:
# >> Custom kernel arguments.
# arguments:
# - key1=val1
# - key2=val2
# >> Modules to build and possibly load automatically.
# modules:
# - source-dir: virtual_touchscreen/
# autoload: no
# >> The output section defines properties of the output image.
output:
# >> OSTree deployment configuration (relevant also for Easy Installer output).
#ostree:
#branch: Cleanbot-Tezi_5.4.0+build.10.CUSTOM
# commit-subject: "OSTree commit subject"
# commit-body: "OSTree commit body"
# >> Parameters for deploying to an Easy Installer image.
easy-installer:
# >> Output directory of the customized image (REQUIRED):
local: Cleanbot-Tezi_5.5.0+build.11.CUSTOM
# >> Information shown by Toradex Easy Installer:
name: "Cleanbot TorizonCore 5.5.0 "
description: "Torizoncore 5.5.0 +build.11 customized for Cleanbot: No Conainters"
# licence: files/custom-licence.html
# release-notes: files/custom-release-notes.html
#bundle:
# >> Choose one of the options:
# >> (1) Specify a docker-compose file whose referenced images will be downloaded.
# >> Properties platform, username, password and registry are optional.
#compose-file: files/docker-compose.yml
# platform: linux/arm/v7
# username: "${USERNAME}"
# password: "${PASSWORD}"
# registry: hub.docker.com
# >> (2) Specify a local directory containing the bundled images (previously
# >> obtained by 'torizoncore-builder bundle' command).
# dir: bundle/
main changes we do is to free up the GPIO7
//free up GPIO7.
/dts-v1/;
/plugin/;
compatible = "toradex,apalis-imx8";
&pciea{
status="disabled";
®_pcie_switch{
status="disabled";
changes directory file listing- its mainly the IP setting of network interface and fstab file that is changed.
njha@comp:~/tcbworkdir/changes_20220310$ ls -R
usr
./usr:
etc
./usr/etc:
NetworkManager fstab group gshadow ipk-postinsts shadow
./usr/etc/NetworkManager:
system-connections
./usr/etc/NetworkManager/system-connections:
network0.nmconnection
./usr/etc/ipk-postinsts:
when i got the changes from the running module it did not have a display connected to it. Could this cause it thought i thought hdmi should be detect normally when a display is connected or not.
as my image doesn’t really contain anything proprietary i can upload it if needed to be investigated.
apalis imx8qm 1.1B and 1.1C on two separate ixora carrier boards.
