I’m trying to add the library libnode.so from my custom recipe but I get the following error:
Log data follows:
| DEBUG: Executing python function extend_recipe_sysroot
| NOTE: Direct dependencies are ['/home/joao/projetos/mT100_imx7_2.8/build/../layers/openembedded-core/meta/recipes-devtools/quilt/quilt-native_0.65.bb:do_populate_sysroot', '/home/joao/projetos/mT100_imx7_2.8/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-runtime_7.3.bb:do_populate_sysroot', '/home/joao/projetos/mT100_imx7_2.8/build/../layers/openembedded-core/meta/recipes-devtools/gcc/gcc-cross_7.3.bb:do_populate_sysroot', '/home/joao/projetos/mT100_imx7_2.8/build/../layers/openembedded-core/meta/recipes-core/glibc/glibc_2.26.bb:do_populate_sysroot', 'virtual:native:/home/joao/projetos/mT100_imx7_2.8/build/../layers/openembedded-core/meta/recipes-devtools/pseudo/pseudo_1.8.2.bb:do_populate_sysroot']
| NOTE: Installed into sysroot: []
| NOTE: Skipping as already exists in sysroot: ['quilt-native', 'gcc-runtime', 'gcc-cross-arm', 'glibc', 'pseudo-native', 'linux-libc-headers', 'libgcc', 'xz-native', 'binutils-cross-arm', 'libtool-native', 'zlib-native', 'texinfo-dummy-native', 'libmpc-native', 'autoconf-native', 'gmp-native', 'mpfr-native', 'gnu-config-native', 'automake-native', 'gettext-minimal-native', 'bison-native', 'flex-native', 'm4-native']
| DEBUG: Python function extend_recipe_sysroot finished
| DEBUG: Executing shell function do_install
| install: cannot create regular file '/home/joao/projetos/mT100_imx7_2.8/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/library-test/1.0-r0/image/usr/lib/libnode.so': No such file or directory
| ERROR: Function failed: do_install (log file is located at /home/joao/projetos/mT100_imx7_2.8/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/library-test/1.0-r0/temp/log.do_install.18845)
ERROR: Task (/home/joao/projetos/mT100_imx7_2.8/build/../myTapp-OS/oe_core/meta-mytapp/recipes-mytapp/recipes-core/library-test.bb:do_install) failed with exit code '1'
NOTE: Tasks Summary: Attempted 5221 tasks of which 5218 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
My recipe library_test.bb:
SUMMARY = "Test"
DESCRIPTION = ""
LICENSE = "CLOSED"
PR = "r0"
SRC_URI = "file://files.tar.gz"
SOLIBS = ".so"
FILES_SOLIBSDEV = ""
do_install() {
install -m 0644 ${WORKDIR}/files/libnode.so ${D}${libdir}/libnode.so
FILES_${PN} += "${libdir}/libnode.so"
The content of files.tar.gz:
├── files
│ └── libnode.so
The main cause should be:
I followed a lot of examples but it doesn’t work. Am i missing anything?
