Hi, we have compile kernel and modules from source (without changing anything, just for test) and system boots correctly but end0 is not linking
The system is a viola board with colibri imx8x
kernel 6.6.129 downstream and with this modules loaded when system boots:
root@zic-514X:\~# lsmod
Module Size Used by
mwifiex_pcie 49152 0
mwifiex 270336 1 mwifiex_pcie
cfg80211 372736 1 mwifiex
rfkill 20480 2 cfg80211
evdev 20480 0
cdns3 45056 0
cdns_usb_common 20480 1 cdns3
caam_jr 163840 0
caamkeyblob_desc 16384 1 caam_jr
caamhash_desc 12288 1 caam_jr
caamalg_desc 36864 1 caam_jr
aes_ce_cipher 12288 0
ghash_ce 16384 0
crypto_engine 12288 1 caam_jr
authenc 12288 1 caam_jr
gf128mul 12288 1 ghash_ce
mcp251x 24576 0
libaes 12288 2 aes_ce_cipher,ghash_ce
sha2_ce 12288 0
libdes 20480 1 caam_jr
snd_soc_simple_card 20480 0
sha256_arm64 20480 1 sha2_ce
crypto_null 12288 1 authenc
can_dev 36864 1 mcp251x
sha1_ce 12288 0
rtc_imx_sc 12288 1
imx_sc_thermal 12288 0
sha1_generic 12288 1 sha1_ce
nvmem_imx_ocotp_scu 12288 1
snd_soc_simple_card_utils 24576 1 snd_soc_simple_card
sec_enclave 53248 0
rng_core 16384 2 sec_enclave,caam_jr
phy_fsl_imx8q_pcie 12288 1
gpio_keys 16384 0
fsl_imx8_ddr_perf 28672 0
usb3503 12288 0
phy_cadence_salvo 12288 1
phy_mxs_usb 20480 1
cdns3_imx 16384 0
ci_hdrc_imx 24576 0
snd_soc_sgtl5000 36864 1
ci_hdrc 57344 1 ci_hdrc_imx
ulpi 16384 1 ci_hdrc
ehci_hcd 81920 1 ci_hdrc
roles 12288 2 cdns_usb_common,ci_hdrc
gpio_fxl6408 12288 4
gpio_regmap 12288 1 gpio_fxl6408
usbmisc_imx 24576 1 ci_hdrc_imx
imx8qxp_adc 12288 0
pwm_imx27 12288 0
snd_soc_fsl_sai 36864 2
snd_soc_fsl_utils 12288 1 snd_soc_fsl_sai
imx_pcm_dma 12288 1 snd_soc_fsl_sai
imx8_media_dev 20480 0
imx8qxp_pixel_combiner 12288 0
caam 28672 1 caam_jr
error 20480 5 caamalg_desc,caamkeyblob_desc,caamhash_desc,caam,caam_jr
spi_fsl_lpspi 20480 0
amphion_vpu 114688 0
irq_imx_irqsteer 12288 0
fuse 126976 1
ip_tables 24576 0
x_tables 32768 1 ip_tables
ipv6 430080 18
autofs4 40960 2
this is the output from dmesg and ip address:
root@zic-514X:~# ip address
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: end0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
link/ether 00:14:2d:86:72:91 brd ff:ff:ff:ff:ff:ff
altname enx00142d867291
inet 172.16.1.249/32 scope global end0
root@zic-514X:~# dmesg |grep fec
[ 1.530027] fec 5b040000.ethernet eth0: registered PHC device 0
[ 6.309897] fec 5b040000.ethernet end0: renamed from eth0
the systems was loaded to board with TEZI.. can be something related to u-boot initialization of ethernet interface?
some ideas? thanks!
