How to add custom Device Tree to build ? so that I can flash my custom Device Tree.
I can’t Directly copy .dtb file because I have mounted my rootfs as readonly so mmcblk0p1 is not mounting on /media/mmcblk0p1 where all files are there like zImage & .dtb files.
So what will be the procedure to add my custom Device Tree to build process so that I can Flash using ./update.sh .
My custom DTB file name is imx6q-apalis-eval_v1.dtb.
please reply fast.
hi @Hitesh
Could you provide the software version of your module?
Did you try adding the device to the image before flashing the image to the module?
For adding your devicetree to the build, please have a look here.
Best regards, Jaski
I did with my way I have mounted rootfs as RW and manually changed the mmc mounting and copy device tree file inside mmc. Everything is working properly on next boot. All the functionality remain Read-Only and Device tree also get updated.
