Colibri Evaluation Board V3.2
Colibri iMX6ULL 1GB IT
I tried the guide above, but custom defconfig does not apply.
I would like to add the mcp3422 driver to the kernel.
tree
└── linux
├── linux-toradex
│ ├── asurada-devicetree-file.dts
│ ├── asurada-devicetree-file.dtsi
│ └── defconfig
└── linux-toradex%.bbappend
FILESEXTRAPATHS:prepend := "${THISDIR}/linux-toradex:"
# Prevent the use of in-tree defconfig
unset KBUILD_DEFCONFIG
CUSTOM_DEVICETREE = "asurada-devicetree-file.dts"
CUSTOM_DEVICETREE_INCLUDE = "asurada-devicetree-file.dtsi"
CUSTOM_DEFCONFIG = "defconfig"
SRC_URI += "\
file://${CUSTOM_DEVICETREE} \
file://${CUSTOM_DEVICETREE_INCLUDE} \
SRC_URI += "\
file://${CUSTOM_DEFCONFIG} \
do_configure:append() {
cp ${WORKDIR}/${CUSTOM_DEVICETREE} ${S}/arch/arm/boot/dts
cp ${WORKDIR}/${CUSTOM_DEVICETREE_INCLUDE} ${S}/arch/arm/boot/dts
- defconfig
CONFIG_MCP3422=y
Hello, did you see the comments made by ToradexAI?
by adding
do_configure_append() {
echo “CONFIG_MCP3422=y” >> ${B}/.config
oe_runmake oldconfig
in linux-toradex%.bbappend, you can force CONFIG_MCP3422 configuration
Is building image working for you currently?
Thank you
Jung Hyun Jeong
I modified the linux-toradex%.bbappend as below and built it, but it doesn’t work.
In defconfig file of the imx_yocto\build\tmp\work-shared\colibri-imx6ull-emmc\kernel-source.kernel-meta\configs folder, CONFIG_MCP3422=y is not added.
SRC_URI += "\
# For arm32 bit devices
# cp ${WORKDIR}/${CUSTOM_DEVICETREE} ${S}/arch/arm/boot/dts
# For arm64 bit freescale/NXP devices
echo "CONFIG_MCP3422=y" >> ${B}/.config
Easiest way to change kernel config is to create a config fragment. In your case create a file like “enable-MCP3422.cfg” containing just the one line you like to change and add “enable-MCP3422.cfg” to SRC_URI in your recipe.
This should change the kernel defconfig as required (at least it did it for me on Colibri iMX6ULL 512MB WB) .
For more complex config changes you can use “bitbake virtual/kernel -c menuconfig”, apply your changes there, save them and call “bitbake virtual/kernel -c diffconfig”. This will create the file “fragment.cfg” containing only the changes you made to the original kernel config. Copy that to your layer and rename it as you like.
Adding a custom tree might be a bit more complex for NAND-based Colibris, as it has to be added to the kernel device tree, to the u-boot environment and to “image.json” in your Tezi image.
these commands will show actual running kernel config.
Please use these commands to check on the evaluation board that kernel config is running or not
cat /proc/config.gz | gunzip > running.config
or,
zcat /proc/config.gz > running.config
