Current uuu versio is too low, error while using recovery mode from Windows
I try to follow the guide to install easy installer after i played with Boot2QT on an Apalis IMX8 QP.
I downloaded easy installer V 2.0b3 on my windows 10 PC.
I entered recovery mode successfully as far as i can tell.
Connected the OTG port with the PC.
Launched recovery-windows.bat. I got the following error:
Downloading Toradex Easy Installer...
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.2.135-0-gacaf035
Wait for Known USB Device Appear...
Error: Current uuu version is too low, please download latest one
ECHO is off. Failed downloading Tezi
Press any key to continue . . .
Any idea what is the issue
I checked Daniel’s module on my setup with serial attached on the eval board. With tezi 2.0b3 I get the same error as daniel above.
With tezi 2.0b2 the batch script starts but then hangs as follows:
Success 0    Failure 0
         1/ 0 [                                      ]
1:443    1/ 1 [=================100%=================] SDPS: boot -f ../flash.bin
On the serial console I see the following:
U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g25f68add54 (Jul 17 2019 - 00:34:05 +0000)
CPU:   Freescale i.MX8QM revB A53 at 1200 MHz at 30C
DRAM:  2 GiB
MMC:   FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
In:    serial
Out:   serial
Err:   serial
Model: Toradex Apalis iMX8 QuadPlus 2GB Wi-Fi / BT V1.0B, Serial# 06517921
 BuildInfo:
  - SCFW cb6f758b, SECO-FW d7523fe8, IMX-MKIMAGE dd023400, ATF d6451cc
  - U-Boot 2018.03-toradex_imx_v2018.03_4.14.78_1.0.0_ga-bringup+g25f68add54
switch to partitions #0, OK
Detect USB boot. Will enter fastboot mode!
Net:   eth0: ethernet@5b040000
Fastboot: Normal
Boot from USB for mfgtools
Use default environment for                              mfgtools
Run bootcmd_mfg: fastboot 0
Is there a known good version of easy installer that works with the Quad plus?
For most later i.MX 8/8X SKUs the latest Tezi is required due to some USB IDs previously having been missing. That said, one could maybe use earlier Tezi with later uuu.auto file found in the recovery folder.
I believe Ming updated to a later uuu version but I fear only for Linux and not for Windows.
Thanks a lot. I assume somebody follows up with Ming. Or is he here on the community?
Hi @daniel.tx
Either you can change the version of uuu to 1.2.39 in uuu.auto file or use the newest uuu.exe file?
