We are using Verdin iMX8M Plus Quad 4GB IT Toradex SoM in design. We are deriving 1.8V from SoM. We want to know maximum worst case current consumption at 25 deg C and 85 deg C. We are providing 5V as power supply to SoM.
Parimal
Parimal
I’d be glad to help with power consumption information for your Verdin iMX8M Plus design! However, to provide you with the most accurate power consumption data, could you let me know which OS and version you are running on the device?
You can use the tdx-info command to get detailed information about your setup. More details about this command can be found at: Getting Device Information with Tdx-Info | Toradex Developer Center
Based on the available documentation, I can provide power consumption measurements for the 0063 Verdin iMX8M Plus Quad 4GB IT V1.1A module (1). The testing was performed using:
The maximum stress test scenario shows 4.43W mean power consumption and 5.26W peak power consumption for the “Max stress: all cores stressed, glmark2, iperf3 Ethernet with phy on module” test case (1).
For designing and scaling power supplies, the documentation recommends following the Verdin Family Specification or Verdin Carrier Board Design Guide to ensure compatibility with all existing and future Verdin modules (2).
The documentation notes that a die temperature increase from 25°C to 125°C will increase the leakage by a factor of 10 (2). This means power consumption will be higher at 85°C compared to 25°C due to increased leakage currents.
Please note that power consumption varies depending on:
The results were achieved by simulating ideal scenarios, and applications in different conditions may not achieve the exact same results (1).
Once you provide your OS version information, I can give you more specific guidance for your particular setup.
Could you please provide 5V worst case current conusmption with maximum loading of the SoM?
Parimal
Based on the available power consumption data for the Verdin iMX8M Plus Quad 4GB IT V1.1A, I can provide you with the worst-case current consumption figures when powered with a 5V supply (1).
For the 0063 Verdin iMX8M Plus Quad 4GB IT V1.1A module, the worst-case scenario shows (1):
Converting these power figures to current consumption at 5V:
The documentation indicates that die temperature increases significantly affect power consumption (2). Specifically, a die temperature increase from 25°C to 125°C will increase leakage by a factor of 10 (2). This means:
Other demanding scenarios from the test results include (1):
For your worst-case design calculations, I recommend using the peak power of 6.07W, which translates to 1.214A at 5V supply for the standard maximum stress test, with additional margin for temperature effects at 85°C.
