I compared the Makefiles of my x86_64 environment with the one of my cross-compiling environment.
I came across these lines:
STRIP = strip | STRIP = $(OE_QMAKE_STRIP)
-$(STRIP) --strip-unneeded $(INSTALL_ROOT)/home/lars. | -$(STRIP) --strip-unneeded $(INSTALL_ROOT)/home/oe/oe
So in the cross-compiling environment the build tools are defined by environment variables.
This works for most of the tools, e.g.:
echo $OE_QMAKE_CC
arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mthumb-interwork -mfloat-abi=hard -mfpu=neon --sysroot=/home/oe/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi
But echo $OE_QMAKE_STRIP is empty.
I looked for the occurrence of OE_QMAKE_STRIP
$grep OE_QMAKE_STRIP -r /home/oe/oecore-x86_64/
/home/oe/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/qmodule.pri:OE_QMAKE_STRIP = echo
/home/oe/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++/qmake.conf:QMAKE_STRIP = $(OE_QMAKE_STRIP)
and compared this with the occurrence of OE_QMAKE_CC
$ grep OE_QMAKE_CC -r /home/oe/oecore-x86_64/
/home/oe/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/qmodule.pri:OE_QMAKE_CC = arm-angstrom-linux-gnueabi-gcc -march=armv7-a -mthumb -mthumb-interwork -mfloat-abi=hard -mfpu=neon --sysroot=/home/oe/oe-core/build/out-glibc/sysroots/colibri-t30
/home/oe/oecore-x86_64/sysroots/armv7at2hf-vfp-neon-angstrom-linux-gnueabi/usr/lib/qt5/mkspecs/linux-oe-g++/qmake.conf:QMAKE_CC = $(OE_QMAKE_CC)
/home/oe/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/environment-setup.d/qt5.sh:export OE_QMAKE_CC=$CC
So OE_QMAKE_CC=$CC but the qt5.sh is missing the corresponding line.
STRIP is defined:
$ echo $STRIP
arm-angstrom-linux-gnueabi-strip
So I added an export for OE_QMAKE_STRIP:
--- /home/oe/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/environment-setup.d/qt5.sh.orig 2016-09-28 14:44:34.316335999 +0200
+++ /home/oe/oecore-x86_64/sysroots/x86_64-angstromsdk-linux/environment-setup.d/qt5.sh 2016-09-30 10:04:32.900442211 +0200
@@ -6,6 +6,7 @@
export OE_QMAKE_CXX=$CXX
export OE_QMAKE_LINK=$CXX
export OE_QMAKE_AR=$AR
+export OE_QMAKE_STRIP=$STRIP
export QT_CONF_PATH=$OECORE_NATIVE_SYSROOT/usr/bin/qt5/qt.conf
export OE_QMAKE_LIBDIR_QT=`qmake -query QT_INSTALL_LIBS`
export OE_QMAKE_INCDIR_QT=`qmake -query QT_INSTALL_HEADERS`
and sourced the cross-toolchain’s environment setup script again:
. /home/oe/oecore-x86_64/environment-setup-armv7at2hf-vfp-neon-angstrom-linux-gnueabi
so that OE_QMAKE_STRIP is defined:
$ echo $OE_QMAKE_STRIP
and now make install runs without error.
