Cross compile PJSIP Colibri iMX7
I want to install PJSIP on my Colibri iMX7. I followed the steps provided here adding my pjsip meta-layers according to this document.
I got the .bb file here changing the pjproject_1.5.5.bb named to pjproject_2.6.bb wich is the latest version and the checksums.
The tree of my meta-pjproject is as follow :
meta-pjproject
├── conf
│   └── layer.conf
└── recipes-pjproject
    └── pjproject
        └── pjproject_2.6.bb
In the layer.conf I have :
# We have a conf and classes directory, add to BBPATH
BBPATH .= ":${LAYERDIR}"
# We have recipes-* directories, add to BBFILES
BBFILES += "${LAYERDIR}/recipes-*/*/*.bb \
	    ${LAYERDIR}/recipes-*/*/*.bbappend"
BBFILE_COLLECTIONS += "pjproject-layer"
BBFILE_PATTERN_pjproject-layer = "^${LAYERDIR}/"
BBFILE_PRIORITY_pjproject-layer = "7"
LAYERVERSION_pjproject-layer = "1"
But during the command bitbake -k angstrom-lxde-image and after several hours I have this error.
So I added to the bb file :
LIC_FILES_CHKSUM = "file://MD5SUM.TXT;md5=xxx"
with MD5SUM.TXT containing :
c347a672679e7875ce572e18517884b2  pjproject-2.6.tar.bz2
But now I have this.
Edit:
I changed the recipe for this one based on this discussion but I have this error:
ERROR: configure failed
 ../pjproject-2.6/configure: 2: ../pjproject-2.6/configure: ./aconfigure: not found
Here is the log :
What can I do ? Is there a simpler way to compile a package?
The pjsip recipe you refer is quite old from OE classic. A more recent example might be from this discussion on the mailing list.
Thank you I edited my post according to your comment.
Hi
That depends on the project, usually using OE eases the setup for cross compiling, as most projects did not put much effort into easy cross compiling in their configuration/Makefiles.
What can I do ?
There is a migration guide if one wants to resurrect a recipe of openembedded classic.
In your case I could at least build the package when changing the recipe to this.
Max
Wow… Thank you very much ! You are my hero… I don’t really understand all the things you did but I am going to try to understand them… Thank you again !
Hello!
I also write for devices with colibri iMX7, and I need to build VoIP SIP protocol under Yocto Rocko. Do you have a link to the code? Thanks!
I don’t understand your question. For source code, you can choose any open source SIP Software.
