Create-production-image - ERROR COPY --from=build /home/torizon/app/build-arm/bin /home/torizon/app
Hi. I’m trying to execute create-production-image for test purposes from VS CODE.
I’m using this c-project example:
https://developer.toradex.com/torizon/application-development/ide-extension/application-development-c-example/
I’m following this guide for create the production image:
https://developer.toradex.com/torizon/application-development/ide-extension/generating-production-images/#prepare-your-application-container-for-production
When I press the create-production-image task, I get this error output:
  • Executing task: xonsh /home/boris/lwdir/devel/soft/torizon/c/gpioc/.conf/create-docker-compose-production.xsh /home/boris/lwdir/devel/soft/torizon/c/gpioc v0.0.0 gpioc
Executing task: run-torizon-binfmt <
Container Runtime: docker
Run Arguments: --rm --privileged torizon/binfmt:latest
Container Name: binfmt
Container does not exists. Starting …
Cmd: docker run --name binfmt --rm --privileged torizon/binfmt:latest
Rebuilding rodion82/gpioc:v0.0.0 …
Executing task: apply-torizon-packages-arm <
Applying torizonPackages.json:
Applying to Dockerfile.debug …
:white_check_mark: Dockerfile.debug
Applying to Dockerfile.sdk …
:white_check_mark: Dockerfile.sdk
Applying to Dockerfile …
torizonPackages.json applied
Executing task: build-container-torizon-release-arm <
Compose can now delegate builds to bake for better performance.
To do so, set COMPOSE_BAKE=true.
[+] Building 20.4s (14/15) docker:default
=> [gpioc internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 2.44kB 0.0s
=> WARN: InvalidDefaultArgInFrom: Default value for ARG torizon/cross-toolchain-${IMAGE_ARCH}:${CROSS_SDK_BASE_TAG} results in empty or invalid base image name (line 15) 0.0s
=> [gpioc internal] load metadata for docker.io/torizon/debian:4 3.9s
=> [gpioc internal] load metadata for docker.io/torizon/cross-toolchain-arm:4 0.7s
=> [gpioc internal] load .dockerignore 0.0s
=> => transferring context: 56B 0.0s
=> CACHED [gpioc build 1/6] FROM docker.io/torizon/cross-toolchain-arm:4@sha256:e55473f56bd83ac3eb4d5c900a1be70d2049fe3a3e67210790ca4bcb8f3ed7b3 0.0s
=> [gpioc deploy 1/4] FROM docker.io/torizon/debian:4@sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de 15.1s
=> => resolve docker.io/torizon/debian:4@sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de 0.1s
=> => sha256:6aafc35ac588733109bc0c55587676a69c7a13b7c2d7306cdb389c2db1299c9c 23.94MB / 23.94MB 5.4s
=> => sha256:964b77426128fdfd88ad74c6b52b3199708ff78b540cba07110121a70f46cc49 5.53MB / 5.53MB 4.4s
=> => sha256:a800063b17a2e4ef7df152037c1382b84e681abc0da31ecff1b4681ec79107f6 270B / 270B 2.5s
=> => sha256:89e87a5ad78b8b7741e7209cab96fabdea1893bffe06b036ff3368d2e64063de 2.38kB / 2.38kB 0.0s
=> => sha256:f5b235db6bbf37a9b7cca73ae8774a8e9f143c40a3747c293e23dc7146950cee 6.49kB / 6.49kB 0.0s
=> => sha256:9b8f3f923bc9df60e15af68edfd27ca8b6d50a3f2726931a3c0307baa32a85b2 2.56kB / 2.56kB 0.0s
=> => sha256:4f4fb700ef54461cfa02571ae0db9a0dc1e0cdb5577484a6d75e68dc38e8acc1 32B / 32B 3.2s
=> => sha256:8f1d9fccd10e2a2fa4a5c2bf412412f162f56f487cfdb765d24300a0fa97d1f4 259B / 259B 4.6s
=> => sha256:b1b720b4a1d97ec509012bae116e7894f253cf46af0f1dd890d23e4266382c23 636B / 636B 4.9s
=> => sha256:081e7095ceaad3e74fe1be4f45ee1b74b5d51a8a181199208e2ee4da104fdd01 3.45kB / 3.45kB 5.7s
=> => sha256:ba56d0f4b83174adea37effb0145e35d9beb93c2a45bb1589247a42bfc440d4e 1.98kB / 1.98kB 6.0s
=> => sha256:4166ce5cedfcef6a2cf0ab8ec389b8b0657525178097d228a0eef3c1650a75ca 405B / 405B 6.5s
=> => extracting sha256:6aafc35ac588733109bc0c55587676a69c7a13b7c2d7306cdb389c2db1299c9c 5.4s
=> => sha256:ebd20dfafd08daf2400c46c6d277fa85a0a7dbaa4f331514196c6be836a79b8e 15.28MB / 15.28MB 9.0s
=> => sha256:ff9c0e18d25386de7f8b64d99c07fbb5352647263ed5da783ad07d72c854b486 1.16MB / 1.16MB 7.5s
=> => sha256:7b7f3ff35c6306713c9acf0cea647e86fb4b2e27181568cd60c88edc7cb57a57 172B / 172B 6.9s
=> => extracting sha256:964b77426128fdfd88ad74c6b52b3199708ff78b540cba07110121a70f46cc49 0.7s
=> => extracting sha256:a800063b17a2e4ef7df152037c1382b84e681abc0da31ecff1b4681ec79107f6 0.0s
=> => extracting sha256:4f4fb700ef54461cfa02571ae0db9a0dc1e0cdb5577484a6d75e68dc38e8acc1 0.0s
=> => extracting sha256:8f1d9fccd10e2a2fa4a5c2bf412412f162f56f487cfdb765d24300a0fa97d1f4 0.0s
=> => extracting sha256:b1b720b4a1d97ec509012bae116e7894f253cf46af0f1dd890d23e4266382c23 0.0s
=> => extracting sha256:081e7095ceaad3e74fe1be4f45ee1b74b5d51a8a181199208e2ee4da104fdd01 0.0s
=> => extracting sha256:ba56d0f4b83174adea37effb0145e35d9beb93c2a45bb1589247a42bfc440d4e 0.0s
=> => extracting sha256:4166ce5cedfcef6a2cf0ab8ec389b8b0657525178097d228a0eef3c1650a75ca 0.0s
=> => extracting sha256:ebd20dfafd08daf2400c46c6d277fa85a0a7dbaa4f331514196c6be836a79b8e 0.5s
=> => extracting sha256:ff9c0e18d25386de7f8b64d99c07fbb5352647263ed5da783ad07d72c854b486 0.1s
=> => extracting sha256:7b7f3ff35c6306713c9acf0cea647e86fb4b2e27181568cd60c88edc7cb57a57 0.0s
=> [gpioc build 2/6] RUN apt-get -q -y update && apt-get -q -y install libgpiod-dev:armhf && apt-get clean && apt-get autoremove && rm -rf /var/lib/a 14.3s
=> [gpioc internal] load build context 0.1s
=> => transferring context: 7.68kB 0.0s
=> [gpioc build 3/6] COPY . /home/torizon/app 0.3s
=> [gpioc build 4/6] WORKDIR /home/torizon/app 0.2s
=> [gpioc build 5/6] RUN rm -rf /home/torizon/app/build-arm 0.6s
=> CANCELED [gpioc deploy 2/4] RUN apt-get -y update && apt-get install -y --no-install-recommends libgpiod2:armhf && apt-get clean && apt-get autoremove && rm -rf / 1.2s
=> [gpioc build 6/6] RUN if [ “arm” = “arm64” ] ; then make ARCH=arm CC=aarch64-linux-gnu-gcc ; elif [ “arm” = “armhf” ] ; then make ARCH=arm CC=arm-l 0.7s
=> ERROR [gpioc deploy 3/4] COPY --from=build /home/torizon/app/build-arm/bin /home/torizon/app 0.0s
[gpioc deploy 3/4] COPY --from=build /home/torizon/app/build-arm/bin /home/torizon/app:
failed to solve: failed to compute cache key: failed to calculate checksum of ref b354cafd-74a5-4a05-883c-96b208db81b3::u775cbe13exr4dfwie8r25vg6: “/home/torizon/app/build-arm/bin”: not found
TASK [build-container-torizon-release-arm] exited with error code [1] <
:cross_mark: Error: RuntimeError(‘Error running task: build-container-torizon-release-arm’)
Error cause: Task execution error
xonsh: To log full traceback to a file set: $XONSH_TRACEBACK_LOGFILE =
File “/home/boris/lwdir/devel/soft/torizon/c/gpioc/.conf/create-docker-compose-production.xsh”, line 169, in
xonsh ./.vscode/tasks.xsh run @(f"build-container-torizon-release-{_image_arch}")
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/built_ins.py”, line 220, in subproc_captured_hiddenobject
return xonsh.procs.specs.run_subproc(cmds, captured=“hiddenobject”, envs=envs)
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/procs/specs.py”, line 1107, in run_subproc
return _run_specs(specs, cmds)
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/procs/specs.py”, line 1153, in _run_specs
cp.end()
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/procs/pipelines.py”, line 481, in end
self._end(tee_output=tee_output)
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/procs/pipelines.py”, line 500, in _end
self._raise_subproc_error()
File “/home/boris/.local/pipx/venvs/xonsh/lib/python3.11/site-packages/xonsh/procs/pipelines.py”, line 646, in _raise_subproc_error
raise subprocess.CalledProcessError(rtn, spec.args, output=self.output)
subprocess.CalledProcessError: Command ‘[‘xonsh’, ‘./.vscode/tasks.xsh’, ‘run’, ‘build-container-torizon-release-arm’]’ returned non-zero exit status 54.
  • The terminal process “xonsh ‘/home/boris/lwdir/devel/soft/torizon/c/gpioc/.conf/create-docker-compose-production.xsh’, ‘/home/boris/lwdir/devel/soft/torizon/c/gpioc’, ‘v0.0.0’, ‘gpioc’, ‘’” terminated with exit code: 1.
  • Terminal will be reused by tasks, press any key to close it.
I’m using VS VODE on Debian 12.10.
Thanks in advance.
Hello! Thank you for your detailed explanation and logs—this makes it much easier to help.
The key error is:
failed to solve: failed to compute cache key: failed to calculate checksum of ref ...: “/home/torizon/app/build-arm/bin”: not found
This means the build process expected to find the compiled binaries at /home/torizon/app/build-arm/bin, but that directory (with binaries) does not exist at the time the deploy stage tries to COPY it.
Here’s how you can troubleshoot and resolve this:
1. Check Your Build Process
The build stage should compile your C application and create binaries in /home/torizon/app/build-arm/bin as expected by the Dockerfile.
  • Did the build stage complete successfully before the error?
  • Are there any compilation errors earlier in the logs? Sometimes, if make or the build script fails, binaries are not created.
2. Verify Output Directories
The path /home/torizon/app/build-arm/bin comes from your Dockerfile or build scripts. Verify that:
  • After compilation, the binaries are actually created at that location.
  • You aren’t missing a mkdir -p build-arm/bin or similar step before compiling.
You can review the workspace structure documentation here:
3. Check Your Dockerfile
Ensure that the paths in your Dockerfile match the output of your build process. In particular:
  • The COPY --from=build /home/torizon/app/build-arm/bin /home/torizon/app line expects the bin directory to be present.
  • If you’re using a Makefile, check it is using build-arm/bin for output, not another path.
More on Dockerfile structure:
4. Try a Clean Build
Residual files can cause issues. Try cleaning up all build artifacts and re-running:
make clean
Or manually remove the build-arm directory, then re-run the build.
Extra Tip:
You can try running the build command manually in a terminal to see if the binaries are created and in the expected folder.
References & More Reading:
If you need help inspecting or modifying your Dockerfile or Makefile, please share their contents (or the relevant build sections), and I’ll provide more targeted advice!
Greetings @Oximoron,
As the ToradexAI has suggested, it appears that the process is trying to copy the built binaries but is not finding any. Can you confirm whether any binaries exist in your VSCode project space?
Hi, problem solved.
Dockerfile from template contains an error for production build when create-production-image task is executed.
Original Dockerfile (after c/c++ project is created for first time from VS CODE):
Modified Dockerfile, change “armhf” by “arm” for arm32 builds:
After that, binary is created with success and image uploaded to dockerhub.
Thanks!.
Interesting I was able to confirm this behavior on a quick test. This seems to be a bug on the template. Thank you for reporting this, I’ll bring it to the attention of our team.
