U-Boot 2016.11-2.8.7+g5c2d46b325 (Jun 10 2020 - 16:05:16 +0000)
SoC: tegra124
Reset cause: POR
DRAM: 2 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1, Tegra SD/MMC: 2
In: serial
Out: serial
Err: serial
Model: Toradex Apalis TK1 2GB V1.2A, Serial# 06490759
Net: No ethernet found.
Booting from internal eMMC chip...
reading tegra124-apalis-v1.2-eval.dtb
54353 bytes read in 16 ms (3.2 MiB/s)
reading zImage
5554576 bytes read in 182 ms (29.1 MiB/s)
## Flattened Device Tree blob at 82000000
Booting using the fdt blob at 0x82000000
Using Device Tree in place at 82000000, end 82010450
Starting kernel ...
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.10.40-2.8.7+g063d16eceb57 (oe-user@oe-host) (gcc version 7.3.0 (GCC) ) #1 SMP PREEMPT Wed Jun 10 16:02:37 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=30c7387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine: apalis-tk1, model: Toradex Apalis TK1 on Apalis Evaluation Board, serial: 0
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: f46ff000 - f46ff80f
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer2: 00000000 - 00000000
[ 0.000000] Framebuffer: fa500000 - fb6fffff
[ 0.000000] 2nd Framebuffer: fb700000 - ffefffff
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Vpr: 00000000 - 00000000
[ 0.000000] Tsec: 00000000 - 00000000
[ 0.000000] cma: CMA: reserved 16 MiB at ae800000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] DTS File Name: /workdir/oe/tmp-glibc/work-shared/apalis-tk1/kernel-source/arch/arm/boot/dts/tegra124-apalis-v1.2-eval.dts
[ 0.000000] Tegra12: CPU Speedo value 2261, Soc Speedo value 2241, Gpu Speedo value 2069
[ 0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[ 0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[ 0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[ 0.000000] tegra: PLLP fixed rate: 408000000
[ 0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[ 0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[ 0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[ 0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[ 0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[ 0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[ 0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[ 0.000000] Lowering se maximum rate from 600000000 to 480000000
[ 0.000000] Lowering vde maximum rate from 600000000 to 480000000
[ 0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[ 0.000000] Lowering vi maximum rate from 700000000 to 600000000
[ 0.000000] Lowering isp maximum rate from 700000000 to 600000000
[ 0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[ 0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[ 0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[ 0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[ 0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[ 0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[ 0.000000] Lowering cpu_g maximum rate from 3000000000 to 2065500000
[ 0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[ 0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[ 0.000000] Switching to timer-based delay loop
[ 0.000000] tegra_powergate_init: DONE
[ 0.000000] PERCPU: Embedded 9 pages/cpu @c1e30000 s15156 r8192 d13516 u36864
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 498960
[ 0.000000] Kernel command line: lp0_vec=2064@0xf46ff000 core_edp_mv=1150 core_edp_ma=4000 usb_port_owner_info=2 lane_owner_info=6 emc_max_dvfs=0 pcie_aspm=off user_debug=30 ip=off root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait igb_mac=00:14:2d:63:0a:87 consoleblank=0 no_console_suspend=1 console=tty1 console=ttyS0,115200n8 debug_uartport=lsport,0 fbcon=map:1
[ 0.000000] PCIe ASPM is disabled
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1955MB = 1955MB total
[ 0.000000] Memory: 1953564k/1953564k available, 142564k reserved, 1223676K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef800000 ( 760 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a0d438 (10262 kB)
[ 0.000000] .init : 0xc0a0e000 - 0xc0a84b34 ( 475 kB)
[ 0.000000] .data : 0xc0a86000 - 0xc0b76748 ( 962 kB)
[ 0.000000] .bss : 0xc0b76748 - 0xc0c14a38 ( 633 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:960
[ 0.000000] the number of interrupt controllers found is 5
[ 0.000000] Architected local timer running at 12.00MHz (phys).
[ 0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[ 0.000000] Ignoring duplicate/late registration of read_current_timer delay
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.003490] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[ 0.003557] pid_max: default: 32768 minimum: 301
[ 0.003816] Security Framework initialized
[ 0.003961] Mount-cache hash table entries: 512
[ 0.026483] Initializing cgroup subsys debug
[ 0.026547] Initializing cgroup subsys freezer
[ 0.026628] CPU: Testing write buffer coherency: ok
[ 0.026713] ftrace: allocating 31113 entries in 61 pages
[ 0.067921] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.067962] Setting up static identity map for 0xc0735188 - 0xc0735228
[ 0.071953] ftrace: Allocated trace_printk buffers
[ 0.078653] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.081688] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.084702] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.084904] Brought up 4 CPUs
[ 0.084965] SMP: Total of 4 processors activated.
[ 0.084981] CPU: All CPU(s) started in SVC mode.
[ 0.086052] devtmpfs: initialized
[ 0.094850] pinctrl core: initialized pinctrl subsystem
[ 0.095247] regulator-dummy: no parameters
[ 0.096103] NET: Registered protocol family 16
[ 0.098387] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.099737] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[ 0.101255] console [pstore-1] enabled
[ 0.101295] ramoops: attached 0x200000@0xfa300000, ecc: 0/0
[ 0.101678] cpuidle: using governor ladder
[ 0.101701] cpuidle: using governor menu
[ 0.104981] apalis_tk1_camera_auxdata: update camera lookup table.
[ 0.114350] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[ 0.114802] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[ 0.122673] Wake16 for irq=34
[ 0.128927] platform tegradc.0: IOVA linear map 0x00000000fa500000(1200000)
[ 0.132274] platform tegradc.0: IOVA linear map 0x00000000fb700000(4800000)
[ 0.137453] platform tegradc.1: IOVA linear map 0x00000000fa500000(1200000)
[ 0.140807] platform tegradc.1: IOVA linear map 0x00000000fb700000(4800000)
[ 0.142771] Wake58 for irq=81
[ 0.142841] Wake41 for irq=129
[ 0.142860] Wake43 for irq=129
[ 0.142908] Wake40 for irq=53
[ 0.142925] Wake42 for irq=53
[ 0.146031] Selecting UARTA as the debug console
[ 0.146085] The debug console clock name is uarta
[ 0.148033] PMC DT attribute sysclkreq_high=0, board value=1
[ 0.148058] PMC DT attribute corereq_high=0, board value=1
[ 0.148080] PMC DT attribute cpu_off_timer=0, board value=300
[ 0.148102] PMC DT attribute cpu_timer=0, board value=500
[ 0.148122] PMC DT attribute suspend_mode=0, board value=2
[ 0.148591] Clear bootloader IO dpd settings
[ 0.148762] Loading Apalis TK1 EMC tables.
[ 0.149023] tegra: pll_m is selected as scalable EMC clock source
[ 0.149068] Lowering emc maximum rate from 1200000000 to 924000000
[ 0.149095] tegra: validated EMC DFS table
[ 0.149173] apalis_tk1_edp_init: CPU regulator 12500 mA
[ 0.412654] apalis_tk1_edp_init: GPU regulator 11400 mA
[ 0.413673] swapper/0 isomgr_init(): iso emc max clk=924000KHz
[ 0.413694] swapper/0 isomgr_init(): max_iso_bw=7392000KB[ 0.492472] FUSE: cp_rev 0 ft_rev 0
[ 0.492660] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[ 0.492896] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.492926] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.493262] mc-err: Started MC error interface!
[ 0.503528] bio: create slab <bio-0> at 0
[ 0.504816] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[ 0.504854] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[ 0.504980] +V3.3_MXM: 3300 mV
[ 0.505848] SCSI subsystem initialized
[ 0.506226] usbcore: registered new interface driver usbfs
[ 0.506292] usbcore: registered new interface driver hub
[ 0.506405] usbcore: registered new device driver usb
[ 0.511111] Wake18 for irq=118
[ 0.512066] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x05
[ 0.512096] as3722 4-0040: Device version 1V1 and platform version 1V2
[ 0.512123] as3722 4-0040: Final OTP version 1V2
[ 0.512971] Wake18 for irq=118
[ 0.515546] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[ 0.515790] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.515853] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.515911] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.515944] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.515975] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.516007] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.516078] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.516111] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.516142] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.516219] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.516250] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.516281] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.516312] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.516344] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.516378] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.516409] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.516440] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.516472] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.516504] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[ 0.516535] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.516567] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[ 0.516618] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[ 0.516651] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[ 0.516682] as3722-regulator as3722-regulator.0: Consumer c16 does not have device name
[ 0.516720] as3722-regulator as3722-regulator.0: Consumer c19 does not have device name
[ 0.516751] as3722-regulator as3722-regulator.0: Consumer c20 does not have device name
[ 0.516782] as3722-regulator as3722-regulator.0: Consumer c21 does not have device name
[ 0.516813] as3722-regulator as3722-regulator.0: Consumer c22 does not have device name
[ 0.516894] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.516926] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.516984] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.517016] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.517047] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.517078] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[ 0.517110] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[ 0.517141] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[ 0.517172] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[ 0.517203] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.517235] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.517290] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.517371] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[ 0.517402] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[ 0.517434] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[ 0.517468] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[ 0.517523] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.517577] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[ 0.517627] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.517661] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[ 0.517715] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[ 0.518686] +VDD_CPU_AP: 650 <--> 1300 mV at 1000 mV 3500 mA
[ 0.519472] +VDD_CORE: applied init 1150000uV constraint
[ 0.520098] +VDD_CORE: 700 <--> 1350 mV at 1150 mV 3500 mA
[ 0.521279] +V1.35_VDDIO_DDR(sd2): 1350 mV
[ 0.521608] as3722-sd3: no parameters
[ 0.521940] +V1.05: 1050 mV
[ 0.522821] +V1.8: 1800 mV
[ 0.523191] +VDD_GPU_AP: applied init 1000000uV constraint
[ 0.524076] +VDD_GPU_AP: 650 <--> 1200 mV at 1000 mV 3500 mA
[ 0.524588] +V1.05_AVDD: 1050 mV at 300 mA
[ 0.525450] VDDIO_SDMMC1: 1800 <--> 3300 mV at 3300 mV at 150 mA
[ 0.526125] +V1.2: 1200 mV at 150 mA
[ 0.527369] +V1.05_RTC: 1000 mV at 150 mA
[ 0.527836] AVDD_LVDS0_PLL: applied init 1800000uV constraint
[ 0.527875] AVDD_LVDS0_PLL: 1800 <--> 3300 mV at 1800 mV at 150 mA
[ 0.528227] as3722-ldo5: at 150 mA
[ 0.528585] VDDIO_SDMMC3: 1800 <--> 3300 mV at 150 mA
[ 0.528952] as3722-ldo7: at 150 mA
[ 0.529626] +V3.3_ETH(ldo9): 3300 mV at 150 mA
[ 0.530136] +V3.3_ETH(ldo10): 3300 mV at 150 mA
[ 0.530635] +V1.8_VPP_FUSE: 1800 mV at 150 mA
[ 0.531719] Linux video capture interface: v2.00
[ 0.531776] pps_core: LinuxPPS API ver. 1 registered
[ 0.531817] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.531864] PTP clock support registered
[ 0.532658] Advanced Linux Sound Architecture Driver Initialized.
[ 0.533631] +V1.05_AVDD_HDMI_PLL: 1050 mV
[ 0.533686] +V1.05_AVDD_HDMI_PLL: supplied by +V1.05
[ 0.533934] reg-fixed-sync-voltage 2.regulator: Consumer c7 does not have device name
[ 0.533971] reg-fixed-sync-voltage 2.regulator: Consumer c8 does not have device name
[ 0.534010] reg-fixed-sync-voltage 2.regulator: Consumer c11 does not have device name
[ 0.534051] reg-fixed-sync-voltage 2.regulator: Consumer c15 does not have device name
[ 0.534083] reg-fixed-sync-voltage 2.regulator: Consumer c16 does not have device name
[ 0.534116] reg-fixed-sync-voltage 2.regulator: Consumer c17 does not have device name
[ 0.534148] reg-fixed-sync-voltage 2.regulator: Consumer c18 does not have device name
[ 0.534914] +V3.3: 3300 mV
[ 0.535192] reg-fixed-sync-voltage 3.regulator: Consumer c3 does not have device name
[ 0.535333] 5V_SW: 5000 mV
[ 0.535641] VCC_USBO1: 5000 mV
[ 0.535972] VCC_USBH(2A|2C|2D|3|4): 5000 mV
[ 0.539019] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[ 0.541471] tegra: failed to map regulator to power detect cell pwrdet_cam(-517)
[ 0.541512] tegra: failed to map regulator to power detect cell pwrdet_pex_ctl(-517)
[ 0.541844] tegra: failed regulators mapping - io power detection is left always on
[ 0.541875] Switching to clocksource arch_sys_counter
[ 0.564824] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.565028] nvmap_page_pool_init: Total MB RAM: 1923
[ 0.565053] nvmap_page_pool_init: nvmap page pool size: 61560 pages (240 MB)
[ 0.565216] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.565390] iram: dma coherent mem declare 0x0000000040001000,258048
[ 0.566245] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[ 0.566410] nvmap:inner cache maint threshold=2097152
[ 0.576501] Wake39 for irq=52
[ 0.576593] tegra-otg tegra-otg: otg transceiver registered
[ 0.576985] NET: Registered protocol family 2
[ 0.577743] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.577969] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.578162] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.578223] TCP: reno registered
[ 0.578248] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.578305] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.578660] NET: Registered protocol family 1
[ 0.579094] RPC: Registered named UNIX socket transport module.
[ 0.579120] RPC: Registered udp transport module.
[ 0.579139] RPC: Registered tcp transport module.
[ 0.579158] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.579466] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[ 0.585151] host1x host1x: initialized
[ 0.586278] CPU PMU: probing PMU on CPU 0
[ 0.586312] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[ 0.586952] tegra_throttle : init passed
[ 0.587074] Tegra cpuquiet initialized: disabled
[ 0.587207] cpu-tegra: init EDP limit: 2065 MHz
[ 0.588220] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[ 0.588643] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[ 0.588891] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[ 0.589180] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.589949] audit: initializing netlink socket (disabled)
[ 0.589994] type=2000 audit(0.564:1): initialized
[ 0.590873] bounce pool size: 64 pages
[ 0.592588] NFS: Registering the id_resolver key type
[ 0.592639] Key type id_resolver registered
[ 0.592661] Key type id_legacy registered
[ 0.592691] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.593363] NTFS driver 2.1.30 [Flags: R/O].
[ 0.593669] fuse init (API version 7.22)
[ 0.594093] msgmni has been set to 1457
[ 0.596568] io scheduler noop registered (default)
[ 0.597037] PCIE.C: tegra_pcie_enable_regulators : regulator hvdd_pex
[ 0.597133] PCIE.C: tegra_pcie_enable_regulators : regulator pexio
[ 0.597212] PCIE.C: tegra_pcie_enable_regulators : regulator avdd_plle
[ 1.200147] PCIE: port 0: link down, retrying
[ 1.501310] PCIE: port 0: link down, retrying
[ 1.802471] PCIE: port 0: link down, retrying
[ 1.903532] PCIE: port 0: link down, ignoring
[ 1.914718] PCI host bridge to bus 0000:00
[ 1.914747] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[ 1.914778] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[ 1.914809] pci_bus 0000:00: root bus resource [io 0x1000-0xffff]
[ 1.914836] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 1.915249] PCI: bus0: Fast back to back transfers disabled
[ 1.915279] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.915979] PCI: bus1: Fast back to back transfers disabled
[ 1.916313] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 1.916342] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 1.916590] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32100000-0x321fffff]
[ 1.916624] pcieport 0000:00:00.0: BAR 7: assigned [io 0x1000-0x1fff]
[ 1.916656] pci 0000:01:00.0: BAR 0: assigned [mem 0x32100000-0x3211ffff]
[ 1.916690] pci 0000:01:00.0: BAR 3: assigned [mem 0x32120000-0x32123fff]
[ 1.916724] pci 0000:01:00.0: BAR 2: assigned [io 0x1000-0x101f]
[ 1.916756] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[ 1.916782] pcieport 0000:00:00.0: bridge window [io 0x1000-0x1fff]
[ 1.916811] pcieport 0000:00:00.0: bridge window [mem 0x32100000-0x321fffff]
[ 1.916854] PCIE: No Link speed change happened
[ 1.916882] PCIE: ASPM not enabled
[ 1.917493] sysedp_create_consumer: unable to create backlight.3, no consumer_data for backlight.3 found
[ 1.918473] tsec tsec: initialized
[ 1.920013] isp isp.0: initialized
[ 1.921033] isp isp.1: initialized
[ 1.922726] falcon vic03.0: initialized
[ 1.923996] falcon msenc: initialized
[ 1.924536] of_dc_parse_platform_data: could not find SD settings node
[ 1.924565] of_dc_parse_platform_data: could not find cmu node
[ 1.924781] tegradc tegradc.0: using mode 1280x800 pclk=71100000 href=1 vref=1
[ 1.927160] tegradc tegradc.0: nominal-pclk:71100000 parent:71000000 div:1.0 pclk:71000000 70389000~77499000
[ 1.944450] tegradc tegradc.0: probed
[ 1.944647] tegradc tegradc.0: switching framebuffer to 1280x800
[ 1.944676] tegradc tegradc.0: Calculated sync href=0 vref=6
[ 1.944704] tegradc tegradc.0: using mode 1280x800 pclk=71103000 href=0 vref=6
[ 1.947162] tegradc tegradc.0: nominal-pclk:71103000 parent:71000000 div:1.0 pclk:71000000 70391970~77502270
[ 1.964807] tegradc tegradc.0: fb registered
[ 1.965083] of_dc_parse_platform_data: could not find SD settings node
[ 1.965110] of_dc_parse_platform_data: could not find cmu node
[ 1.965365] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 1.965845] gpio wake4 for gpio=111
[ 2.965972] tegra-i2c tegra12-i2c.3: --- register dump for debugging ----
[ 2.966004] tegra-i2c tegra12-i2c.3: I2C_CNFG - 0x2c00
[ 2.966030] tegra-i2c tegra12-i2c.3: I2C_PACKET_TRANSFER_STATUS - 0xff0001
[ 2.966058] tegra-i2c tegra12-i2c.3: I2C_FIFO_CONTROL - 0xe0
[ 2.966083] tegra-i2c tegra12-i2c.3: I2C_FIFO_STATUS - 0x800040
[ 2.966108] tegra-i2c tegra12-i2c.3: I2C_INT_MASK - 0xed
[ 2.966132] tegra-i2c tegra12-i2c.3: I2C_INT_STATUS - 0x0
[ 2.966157] tegra-i2c tegra12-i2c.3: msg->len - 1
[ 2.966179] tegra-i2c tegra12-i2c.3: is_msg_write - 1
[ 2.966202] tegra-i2c tegra12-i2c.3: next_msg->len - 128
[ 2.966225] tegra-i2c tegra12-i2c.3: is_next_msg_write - 0
[ 2.966249] tegra-i2c tegra12-i2c.3: buf_remaining - 128
[ 2.966280] tegra-i2c tegra12-i2c.3: i2c transfer timed out, addr 0x0050, data 0x00
[ 2.968925] tegradc tegradc.1: probed
[ 2.970061] tegradc tegradc.1: switching framebuffer to 640x480
[ 2.970093] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 2.970393] tegradc tegradc.1: switching framebuffer to 640x480
[ 2.970402] tegradc tegradc.1: using mode 640x480 pclk=25200000 href=1 vref=1
[ 2.973589] Console: switching to colour frame buffer device 80x30
[ 2.982340] tegradc tegradc.1: fb registered
[ 2.984252] hdmi_state_machine_worker (tid edb7dac0): state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 2.988024] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 2.991662] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[ 2.992412] Serial: 8250/16550 driver, 9 ports, IRQ sharing disabled
[ 2.994625] serial8250.0: ttyS0 at MMIO 0x70006000 (irq = 68) is a Tegra
[ 3.038972] hdmi_state_machine_worker (tid edb7dac0): state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 3.038976] hdmi_disable_l: audio_switch 0
[ 3.038979] hdmi_disable_l: hpd_switch 0
[ 3.038985] hdmi_state_machine_set_state_l: switching from state 0 (Reset) to state 1 (Check Plug)
[ 3.093967] hdmi_state_machine_worker (tid edb7dac0): state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 3.093971] hdmi_disable_l: audio_switch 0
[ 3.093974] hdmi_disable_l: hpd_switch 0
[ 3.093979] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.232295] console [ttyS0] enabled
[ 5.238195] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[ 5.250251] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[ 5.262552] serial-tegra.3: ttyTHS3 at MMIO 0x70006300 (irq = 122) is a SERIAL_TEGRA
[ 5.280142] loop: module loaded
[ 5.285774] nct1008_nct72 4-004c: success in enabling rail vdd_nct72
[ 5.297758] gpio wake35 for gpio=70
[ 5.303783] nct1008_nct72 4-004c: nct1008_probe: initialized
[ 5.312576] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 5.327478] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 5.343137] tegra_profiler: Branch: Dev
[ 5.349681] tegra_profiler: Version: 1.103
[ 5.356418] tegra_profiler: Samples
