On our custom board using Apalis T30 processor we are running the below applications :
- Linux application
- Java based GUI application
a) When we run Linux application and check the CPU usage using top command, it is showing 93%.
b) When we run both Linux aplication and GUI application then CPU usage by
Linux application is 2% and
GUI application is 195%
and we are getting the below messages printed on the console :
[ 276.938097] Pid: 577, comm: java
[ 276.943025] CPU: 3 Not tainted (3.1.10-g8e1745b-dirty #14)
[ 276.948867] PC is at 0x41053e98
[ 276.952006] LR is at 0x410542ec
[ 276.955371] pc : [<41053e98>] lr : [<410542ec>] psr: 60070010
[ 276.955375] sp : 537cc688 ip : 00000000 fp : 537cc758
[ 276.966891] r10: 534a5400 r9 : 00000000 r8 : 486f6198
[ 276.972121] r7 : 00002000 r6 : 00000001 r5 : 486f6188 r4 : 00000000
[ 276.978644] r3 : 0000000a r2 : 00000000 r1 : 53882bd8 r0 : 484512d0
[ 276.985163] Flags: nZCv IRQs on FIQs on Mode USER_32 ISA ARM Segment user
[ 276.992496] Control: 10c5387d Table: a358c04a DAC: 00000015
[ 276.998330] [] (show_regs+0x0/0x58) from [] (__do_user_fault+0x64/0xac)
[ 277.006667] r5:00000000 r4:e6bd7ae0
[ 277.010272] [] (__do_user_fault+0x0/0xac) from [] (do_page_fault+0x208/0x218)
[ 277.019136] r7:e6bd7ae0 r6:00000000 r5:00030001 r4:e3427fb0
[ 277.024829] [] (do_page_fault+0x0/0x218) from [] (do_DataAbort+0x48/0xac)
[ 277.033354] [] (do_DataAbort+0x0/0xac) from [] (__dabt_usr+0x38/0x40)
[ 277.041531] Exception stack(0xe3427fb0 to 0xe3427ff8)
[ 277.046573] 7fa0: 484512d0 53882bd8 00000000 0000000a
[ 277.054745] 7fc0: 00000000 486f6188 00000001 00002000 486f6198 00000000 534a5400 537cc758
[ 277.062951] 7fe0: 00000000 537cc688 410542ec 41053e98 60070010 ffffffff
[ 277.069564] r7:00002000 r6:ffffffff r5:60070010 r4:41053e98
[ 277.075916] pgd = e358c000
[ 277.078630] [00000000] *pgd=a6b59831, *pte=00000000, *ppte=00000000
[ 277.084909]
Kindly shed some light on this issue.
Thanks,
Shiva Shankar K.
