As I tried to plug CP2102 USB to UART TTL Converter into Colibri iMX6ULL, it was not detected as usb serial device and hence no /dev/ttyUSBx was assigned to it.
How can I install CP210x drivers on this module?
Could you please specify which exactly “Embedded Linux” image you are using?
