I have a sensor with serial communcation using a CP2102 USB to UART converter. My platform is a Colibrí imx7D running Linux 2.7.3.
I cannot find the ttyUSBX port so how can I install the drivers?
Below some prompts from the Linux terminal
root@colibri-imx7:~# dmesg | grep tty
[ 0.000000] Kernel command line: ubi.mtd=ubi root=ubi0:rootfs rootfstype=ubifs ubi.fm_autoconvert=1 console=tty1 console=ttymxc0,115200n8 consoleblank=0 video=mxsfb:800x480M-16@60
[ 0.002413] console [tty1] enabled
[ 0.267375] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 273, base_baud = 1500000) is a IMX
[ 0.992946] console [ttymxc0] enabled
[ 3.069295] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.399280] systemd[1]: Created slice system-getty.slice.
[ 3.548544] imx_rpmsg_tty rpmsg0: new channel: 0x400 -> 0x0!
[ 3.556142] Install rpmsg tty driver!
root@colibri-imx7:~# lsusb
Bus 002 Device 005: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
Bus 002 Device 004: ID 046a:b091 Cherry GmbH
Bus 002 Device 003: ID 222a:0001
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
