i have generate a PWM signal and count 4096 rising edges.(PWM is necessary ) for now i’m using just a GPIO interrupt, i connect the PWM output to the GPIO pin but i would like to know if it would be possible to not sacrifice GPIO’s
PWM Generated by:
echo 0 > export
echo 1000000 > pwmchip1/pwm0/period
echo 500000 > pwm0/duty_cycle
echo 1 > pwm0/enable
echo “normal” > pwm0/polarity
