I’m facing a problem that I’m not able to solve for days. In fact, I’m able to compile under Yocto and deploy core image minimal, core image minimal with gstreamer 1.0 (and fsl plugins), core image minimal with Qt5 & eglfs. But I’m not able to make Qt5 and Gstreamer work together. I don’t use Qgstreamer or so, I just try to execute gst-launch-1.0 in console. But whatever the gst command (inspect, laucnh) I write, I’ve got this issue :
(gst-plugin-scanner:648): GLib-GObject-WARNING *: cannot register existing type 'GstImxCompositorPad'
(gst-plugin-scanner:648): GLib-CRITICAL **: g_once_init_leave: assertion 'result!=0' failed
and then I have to quit with CTRL+C to stop the process.
My local.conf :
MACHINE ?= 'apalis-imx6'
DISTRO ?= 'poky'
PACKAGE_CLASSES ?= "package_rpm"
EXTRA_IMAGE_FEATURES = "debug-tweaks ssh-server-openssh"
USER_CLASSES ?= "buildstats image-mklibs"
PATCHRESOLVE = "noop"
BB_DISKMON_DIRS = "\
STOPTASKS,${TMPDIR},1G,100K \
STOPTASKS,${DL_DIR},1G,100K \
STOPTASKS,${SSTATE_DIR},1G,100K \
STOPTASKS,/tmp,100M,100K \
ABORT,${TMPDIR},100M,1K \
ABORT,${DL_DIR},100M,1K \
ABORT,${SSTATE_DIR},100M,1K \
ABORT,/tmp,10M,1K"
PACKAGECONFIG_append_pn-qemu-native = " sdl"
PACKAGECONFIG_append_pn-nativesdk-qemu = " sdl"
ASSUME_PROVIDED += "libsdl-native"
CONF_VERSION = "1"
DL_DIR ?= "${BSPDIR}/downloads/"
IMAGE_INSTALL_append = " gcc g++ binutils libgcc libgcc-dev libstdc++ libstdc++-dev libstdc++-staticdev \
autoconf automake ccache chkconfig glib-networking glibmm \
packagegroup-core-buildessential pkgconfig \
boost cmake zlib glib-2.0 packagegroup-fsl-tools-testapps \
cpufrequtils \
nano \
gdb \
openssh-sftp-server \
imx-vpu \
imx-test \
firmware-imx \
qtbase-fonts \
qtbase-plugins \
qtbase-tools \
qtdeclarative \
qtdeclarative-plugins \
qtdeclarative-tools \
qtdeclarative-qmlplugins \
qtmultimedia \
qtmultimedia-plugins \
qtmultimedia-qmlplugins \
qtimageformats-plugins \
qtsystems \
qtsystems-tools \
qtsystems-qmlplugins \
qtgraphicaleffects-qmlplugins \
qtconnectivity-qmlplugins \
cairo pango fontconfig freetype pulseaudio dbus \
i2c-tools \
gstreamer1.0-plugins-imx \
gst1.0-fsl-plugin \
gstreamer1.0-plugins-base \
psplash \
DISTRO_FEATURES_remove = "x11 wayland"
IMAGE_INSTALL_remove = "eglinfo-x11"
KERNEL_IMAGETYPE = "uImage"
ACCEPT_FSL_EULA = "1"
IMAGE_FSTYPES += "ext3"
PREFERRED_PROVIDER_psplash = "meta-avt"
What maybe wrong ?
In another image (3.14.28 toradex but customized) , gstreamer works but when I execute Qt5cinematic demo :
Could not open egl display
Maybe I disabled a feature in menuconfig ?
