Corrupt image when building Torizon minimal
Hello
We are building a custom Torizon minimal OS for our devices. What we noticed is that sometimes when building it produces a “corrupt” image.
The build process finishes without errors and the image is uploaded to Torizon Cloud successfully. But when we install it on the device we see a lot of errors like here:
[FAILED] Failed to start Network Name Resolution.
[FAILED] Failed to start Network Time Synchronization.
[FAILED] Failed to start Network Configuration.
[FAILED] Failed to start Avahi mDNS/DNS-SD Stack.
[FAILED] Failed to start D-Bus System Message Bus.
[DEPEND] Dependency failed for Network Manager.
[DEPEND] Dependency failed for Network Manager Wait Online.
[FAILED] Failed to start Bluetooth service.
[FAILED] Failed to start System Logger Daemon "default" instance.
[FAILED] Failed to start Disk device monitor based on udisks2.
The device can’t connect anymore with the cloud agent so we can’t install another working software either.
We dug a bit deeper and found that the group file seems to be incomplete:
# NSS altfiles module is installed. Default user, group and shadow files are in
# /usr/lib/
adm:x:4:torizon
dialout:x:20:torizon
sudo:x:27:torizon
audio:x:29:torizon
video:x:44:torizon
plugdev:x:46:torizon
gpio:x:49:torizon
i2cdev:x:51:torizon
spidev:x:52:torizon
pwm:x:54:torizon
users:x:100:torizon
input:x:101:torizon
torizon:x:1000:
We are using a fork of your torizon-manifest repo and build using bitbake. My assumption is that it happens when we change branches and start a new build. Maybe you have some more insight why this happens?
Ian
I’d be glad to help troubleshoot this issue with your custom Torizon minimal OS build! To provide the most accurate guidance, could you let me know:
  • Which hardware platform are you using?
  • Which exact version of Torizon OS are you building from?
You can get this information by running the tdx-info command on a working device. More details about this command are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Initial Analysis
Based on the errors you’re seeing, this appears to be a filesystem corruption issue affecting system groups and potentially other core system files (1). The incomplete /etc/group file you’ve identified is likely causing the cascade of service failures, as many system services depend on proper user/group resolution (1).
Potential Causes for “Corrupt” Images
When building Torizon OS with Yocto, several factors can lead to incomplete or corrupted builds (2):
1. Build State Contamination
Switching branches without proper cleanup can leave residual build artifacts that interfere with new builds (2). The Yocto build system maintains extensive state information that may not be fully reset between branch changes.
2. Incomplete Build Cleanup
The build system stores intermediate files in the build/tmp directory, and these may not be properly cleaned when switching contexts (2).
Recommended Solutions
1. Clean Build Environment
When switching branches in your forked torizon-manifest repo, perform a complete build cleanup (2):
$ rm -rf build/tmp
$ rm -rf build/cache
(2)
2. Verify Git State
Since Torizon OS requires all custom layers to be version controlled by Git for OSTree integration, ensure your branch switches are complete (3):
$ git status
$ git clean -fd
(3)
3. Use Fresh Build Directory
Consider using separate build directories for different branches to avoid cross-contamination (2).
4. Verify Layer Configuration
Check that your conf/bblayers.conf is properly updated for the target branch and that all required layers are present (2).
Once I know your specific hardware platform and Torizon OS version, I can provide more targeted troubleshooting steps for your build environment.
Hello @i.staehli,
This error is not expected.
To be clear, the error only manifests when one of these “Broken” OS packages is sent as an update to the device, correct?
Is the OS update rolled back or does the device gets stuck?
If you flash a device with a TEZI image that was generated on the same Yocto build, does it also have the same problem?
Another point that may be relevant is the build environment.
Is this present only in a specific build machine or across different developers?
Is anything related to the sstate or build temporary files configured differently from default?
Bruno
Hi @bruno.tx
  1. Yes, the errors on the device only appear after the broken OS package is sent to the device
  2. The OS update is not rolled back and we can’t install another update, because it’s not working properly
  3. When flashing with TEZI we get the same errors on the device
  4. So far only I encountered this problem, but we all use the same server to build our images
  5. I’m not familiar with how the sstate or temporary build files can be configured, but we shouldn’t have changed anything from default here
Hello @i.staehli,
Thanks for the clarifications.
I think the first point that would be worth understanding is if the build is using some incorrect cache or if the build is actually following the metadata correctly.
When a problematic build is done, testing the following would help us understand this:
  • Delete the following directories:
    • build-torizon/cache
    • build-torizon/tmp
    • build-torizon/deploy
  • Try to run the build again
I have seen some issues with Yocto and these directories in the past when checking out different branches of layers or doing some changes to the current build setup.
If the build results in valid files after this change, it could be reasonable to automate this to be done every time the layers are changed.
The sstate-cache and downloads should still make the build reuse a lot of previous work.
If the build has the same problem, it would be worth trying again, but also deleting the following directories:
  • sstate-cache
  • downloads
If the build continues to have problems, it would indicate that the metadata (layers) being used to build the image is the problem here.
Maybe there was a partial checkout of some files and somehow the layers are in an invalid state.
The other problem problem I see is the fact that the update does not rollback from a cloud update.
Could you send me the serial logs (or output from dmesg) from a failing system?
If you prefer not to send this publicly here on the community, please send it via a direct message to me or via email to support.eu@toradex.com.
Bruno
Hi @bruno.tx
After deleting the directories cache, tmp and deploy and re-building the resulting image was correct.
In another instance I even did a bitbake -c clean and that also fixes the issue.
I guess we will add such a step once we automate our build process. We were mostly wondering if you know the root cause of this.
I tried sending the log files to suppport.eu@toradex.com, but got this email back:
Address not found
Your message wasn’t delivered to suppport.eu@toradex.com because the address couldn’t be found, or is unable to receive mail.
Kind regards,
Ian
Hello @i.staehli,
Sorry for that, there was a typo in my previous message.
It should actually be support.eu@toradex.com.
Can you try again with this email?
Thanks for the update.
Sometimes temporary files in this directory can be in invalid states.
It is usually the case when builds are abruptly interrupted by a system crash or power down.
However, I have also seen this happen when changing between BSP versions.
Bruno
Thanks @bruno.tx for the insights.
We will also look into configuring the greenboot for the rollback, as you mentioned in the email.
Kind Regards,
Ian
