Hi All,
I’m New into these things.I’m Using Colibri Iris T30 Board with that using Ubuntu18.04 os ; I have done the basic things like controlling GPIO through command line also did the Hello world Program using eclipse.
But i wanted to control(Toggling) the gpio’s using Eclipse.
Also i wanted interface the some digital/analog sensors/.
Please let me know how can be interact with gpio of board using Eclipse IDE(How to Acess the Gpio/i2c/spi/analog)directly,so i can easily work with that.Is that i need any Extra IDE to develop my applications(Like in ARM7 i use Keil IDE/IAR).
Eclipse IDE is a developer-friendly application development tool. User space APIs are the same for makefile based application build setup and Eclipse IDE also.
Please refer above two documentation links for how to develop application and debug using Eclipse. On top of hello-world application add other features of your application like GPIO, I2c, SPI.
Please refer below documentation for accessing peripherals
Dear Sir@raja.tx thanx for your time,
I have done with gpio configuration to toggle the led’s .I have the Build file which generated by eclipse now how can i flash into the my colibri t30 board that contineously run my application?
