Controlling the peripheral in IMX8 with M4 core
Hi @AhmedMobarez,
No worries, feel free to reach out anytime you want.
Hiago.
Hello Hiago @hfranco.tx ,
sorry for commenting on an old thread, let me know if I should post this in a new thread, I just have a small question, how did you figure out that pin 35 and 36 on the Ixora could be used for UART and only from the M4 core 1 and not 0 ?
thank you
Hi @AhmedMobarez,
since it’s a simple question related to the topic, we can discuss it in this thread.
I checked the pin_mux.h files inside the “Hello Wolrd” demo. Here is the diff between pin_mx.h from core0 and core1:
--- cm4_core0/pin_mux.h 2022-08-22 11:04:15.000000000 -0300
+++ cm4_core1/pin_mux.h 2022-08-22 11:04:15.000000000 -0300
@@ -14,23 +14,23 @@
  * Definitions
-/* M40_I2C0_SCL (number AM44), FTDI_M40_UART0_RX */
+/* UART0_RTS_B (number AU45), BB_UART2_RX/J20A[28] */
 /* Routed pin properties */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_PERIPHERAL                   M40__UART0   /*!< Peripheral name */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_SIGNAL                          uart_rx   /*!< Signal name */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_PIN_NAME                   M40_I2C0_SCL   /*!< Routed pin name */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_PIN_FUNCTION_ID       SC_P_M40_I2C0_SCL   /*!< Pin function id */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_LABEL               "FTDI_M40_UART0_RX"   /*!< Label */
-#define BOARD_INITPINS_FTDI_M40_UART0_RX_NAME                "FTDI_M40_UART0_RX"   /*!< Identifier */
+#define BOARD_INITPINS_BB_UART2_RX_PERIPHERAL                         DMA__UART2   /*!< Peripheral name */
+#define BOARD_INITPINS_BB_UART2_RX_SIGNAL                                uart_rx   /*!< Signal name */
+#define BOARD_INITPINS_BB_UART2_RX_PIN_NAME                          UART0_RTS_B   /*!< Routed pin name */
+#define BOARD_INITPINS_BB_UART2_RX_PIN_FUNCTION_ID              SC_P_UART0_RTS_B   /*!< Pin function id */
+#define BOARD_INITPINS_BB_UART2_RX_LABEL                  "BB_UART2_RX/J20A[28]"   /*!< Label */
+#define BOARD_INITPINS_BB_UART2_RX_NAME                            "BB_UART2_RX"   /*!< Identifier */
-/* M40_I2C0_SDA (number AU51), FTDI_M40_UART0_TX */
+/* UART0_CTS_B (number AW49), BB_UART2_TX/J20A[29] */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_PERIPHERAL                   M40__UART0   /*!< Peripheral name */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_SIGNAL                          uart_tx   /*!< Signal name */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_PIN_NAME                   M40_I2C0_SDA   /*!< Routed pin name */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_PIN_FUNCTION_ID       SC_P_M40_I2C0_SDA   /*!< Pin function id */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_LABEL               "FTDI_M40_UART0_TX"   /*!< Label */
-#define BOARD_INITPINS_FTDI_M40_UART0_TX_NAME                "FTDI_M40_UART0_TX"   /*!< Identifier */
+#define BOARD_INITPINS_BB_UART2_TX_PERIPHERAL                         DMA__UART2   /*!< Peripheral name */
+#define BOARD_INITPINS_BB_UART2_TX_SIGNAL                                uart_tx   /*!< Signal name */
+#define BOARD_INITPINS_BB_UART2_TX_PIN_NAME                          UART0_CTS_B   /*!< Routed pin name */
+#define BOARD_INITPINS_BB_UART2_TX_PIN_FUNCTION_ID              SC_P_UART0_CTS_B   /*!< Pin function id */
+#define BOARD_INITPINS_BB_UART2_TX_LABEL                  "BB_UART2_TX/J20A[29]"   /*!< Label */
+#define BOARD_INITPINS_BB_UART2_TX_NAME                            "BB_UART2_TX"   /*!< Identifier */
  * @addtogroup pin_mux
@@ -57,7 +57,7 @@
  * @param ipc scfw ipchandle.
-void BOARD_InitPins(sc_ipc_t ipc);                         /*!< Function assigned for the core: Cortex-M4F[cm4_core0] */
+void BOARD_InitPins(sc_ipc_t ipc);                         /*!< Function assigned for the core: Cortex-M4F[cm4_core1] */
Now you can go to the Apalis iMX8 datasheet and look for pins M40_I2C0_SCL (core 0) and UART0_RTS_B (core 1). On the Ixora board, only the pin UART0_RTS_B is available in the header pin ( you can check the Ixora Datasheet as well), that’s how I found which core was available for me.
Feel free to ask any questions you might have.
Hiago.
