I see that in the integration feeds the first monthly release of Torizon OS 7 for Verdin iMX8M-Plus is available (7.0.0-devel-202409+build.1).
I’m going to start my testing on this release, so that I cab give feedback and be ready for a smooth transition when the first LTS is released.
My question is: which tag should I pull for the several torizon/... containers on Dockerhub with Torizon OS 7? Is this next tag?
Basically I’m interested in:
weston-vivante
chromium
cog
Which debian-slim release they’re based on? So that I can build my custom containers maximising the layer caching.
For testing Torizon OS 7, you should use the next tag for the torizon/... containers on Docker Hub. This tag is typically used for the latest development versions, which would align with your testing of the Torizon OS 7 release.
Regarding the Debian release they are based on, the containers are derived from a minimal variant of the Debian Bookworm release. This should help you in building your custom containers while maximizing layer caching.
Here are the specific tags you should pull for the containers you mentioned:
torizon/weston-vivante:next
torizon/chromium:next
torizon/cog:next
By using these tags, you will ensure that you are working with the most recent development versions that are compatible with Torizon OS 7.
