Hi Ahmed49,
Based on the context provided, it seems like you’re encountering an issue with accessing a container image from your Azure Container Registry (ACR) using the TorizonCore Builder tool. The error message indicates that the image he-varia-torizon is not found or access is denied, which could be due to a few reasons:
Repository Name: Double-check the repository name in your Azure Container Registry. Ensure that
he-varia-torizonis the correct name and that it exists in your registry. -
Authentication: Make sure that you have successfully authenticated with the Azure Container Registry. You mentioned that the username and password are correct, but it’s worth verifying that the authentication tokens are correctly set up on your host machine as per the steps outlined in the context.
Docker Login: The error message suggests that a
docker loginmight be required. Ensure that you have logged in to your Azure Container Registry using Docker on your host machine. You can do this by running:docker login registryName.azurecr.ioUse your Azure credentials to authenticate.
Image Tag: Verify that the tag
latestexists for the imagehe-varia-torizon. If the image is tagged differently, you need to specify the correct tag in yourdocker-compose.ymlfile. -
Network Issues: Ensure there are no network issues preventing access to the Azure Container Registry.
If you’ve checked all the above and the issue persists, you might want to look into the Torizon Cloud Web Interface for more detailed logs or error messages that could provide further insights.
[Your Name]
