I have installed an ext4 formatted Samsung EVO SATA drive into the Apalis Evaluation board v1.1A. Here are the lines from the console during boot:
[ 5.523496] iommu: Adding device 5f020000.sata to group 0
[ 5.531241] ahci-imx 5f020000.sata: phy impedance ratio is not specified.
[ 5.538987] ahci-imx 5f020000.sata: external osc is used.
[ 5.547271] ahci-imx 5f020000.sata: no ahb clock.
[ 5.552086] Can't support > 32 bit dma.
[ 5.555971] ahci-imx 5f020000.sata: Enable 32-bit DMA instead of 64-bit.
[ 5.562756] ahci-imx 5f020000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 5.571727] ahci-imx 5f020000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sadm sds apst
[ 5.583241] scsi host0: ahci-imx
[ 5.586760] ata1: SATA max UDMA/133 mmio [mem 0x5f020000-0x5f02ffff] port 0x100 irq 150
[ 7.490865] ata1.00: ATA-11: Samsung SSD 860 EVO mSATA 250GB, RVT41B6Q, max UDMA/133
[ 7.490872] ata1.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 31/32)
[ 7.495108] ata1.00: supports DRM functions and may not be fully accessible
[ 7.497238] ata1.00: configured for UDMA/133
Executed the following command to copy the root file system on MMC to SATA drive:
rsync -avPHx --numeric-ids / /media/sda1
During the copy operation, there are many many “failed command” messages on the console:
[ 287.782584] ata1.00: status: { DRDY }
[ 287.786241] ata1.00: failed command: WRITE FPDMA QUEUED
[ 287.791467] ata1.00: cmd 61/08:98:f0:e0:85/00:00:1c:00:00/40 tag 19 ncq dma 4096 out
[ 287.791467] res 40/00:20:00:ee:85/00:00:1b:00:00/40 Emask 0x12 (ATA bus error)
[ 287.807205] ata1.00: status: { DRDY }
[ 287.810871] ata1: hard resetting link
[ 288.290595] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 310)
[ 288.297169] ata1.00: supports DRM functions and may not be fully accessible
[ 288.306647] ata1.00: supports DRM functions and may not be fully accessible
[ 288.315696] ata1.00: configured for UDMA/33
[ 288.322070] ata1: EH complete
[ 288.365146] ata1.00: Enabling discard_zeroes_data
I don’t recall getting these errors when I was using Toradex Apalis iMX8 QuadMax 4GB Wi-Fi / Bluetooth V1.0A / NXP i.MX Release Distro 4.9.51-mx8-beta apalis-imx8
Any ideas as to what has changed and how I can eliminate these errors?
