I’m currently facing an issue while trying to connect to the Core M4F1 of the AM62 micro through XDS110, following the procedure outlined in the provided [AM62x MCU+ SDK: CCS Launch, Load and Run]. When attempting to connect to the core, I receive the following error message:
Error connecting to the target: (Error -1274 @ 0x0) Error encountered during connect sequence. The specific reason is unknown but may be the result of trying to access a Core or logic that is inaccessible due to a lack of Power, Clocks, or Authentication (i.e. Security is preventing). If blocked by security, and if supported, access may be allowed after following the Authentication process.
Has anyone else encountered a similar problem? Any help or suggestions would be highly valuable.
What version of the CCS and its environment are you using? Are you able to connect to the M4F0? Also, is the behavior different when you put the SoC into recovery mode and then try to connect to the M4 (do not load Toradex Easy Installer, just keep the SoC in Recovery Mode)?
