Connecting to internet with EC25 (miniPCIe) on Apalis IMX8QM with Ixora
I am trying to connect to the internet using EC25 module. I followed the steps in modem support. Here’s the status information.
apalis-imx8-06852506:~$ mmcli -m 0
  General  |            dbus path: /org/freedesktop/ModemManager1/Modem/0
           |            device id: 8bba08d4823e8787dd5d46ca4d81df1be43443a6
  Hardware |         manufacturer: QUALCOMM INCORPORATED
           |                model: QUECTEL Mobile Broadband Module
           |    firmware revision: EC25EFAR06A09M4G
           |       carrier config: default
           |         h/w revision: 10000
           |            supported: gsm-umts, lte
           |              current: gsm-umts, lte
           |         equipment id: 862348051548204
  System   |               device: /sys/devices/platform/bus@5b000000/5b0e0000.usb/ci_hdrc.1/usb4/4-1/4-1.1
           |              drivers: qmi_wwan, option1
           |               plugin: Quectel
           |         primary port: cdc-wdm0
           |                ports: cdc-wdm0 (qmi), ttyUSB0 (qcdm), ttyUSB2 (at), wwan0 (net),
           |                       ttyUSB1 (gps), ttyUSB3 (at)
  Status   |                 lock: sim-pin2
           |       unlock retries: sim-pin (10), sim-puk (10), sim-pin2 (3), sim-puk2 (10)
           |                state: connected
           |          power state: on
           |          access tech: lte
           |       signal quality: 54% (recent)
  Modes    |            supported: allowed: 2g; preferred: none
           |                       allowed: 3g; preferred: none
           |                       allowed: 4g; preferred: none
           |                       allowed: 2g, 3g; preferred: 3g
           |                       allowed: 2g, 3g; preferred: 2g
           |                       allowed: 2g, 4g; preferred: 4g
           |                       allowed: 2g, 4g; preferred: 2g
           |                       allowed: 3g, 4g; preferred: 3g
           |                       allowed: 3g, 4g; preferred: 4g
           |                       allowed: 2g, 3g, 4g; preferred: 4g
           |                       allowed: 2g, 3g, 4g; preferred: 3g
           |                       allowed: 2g, 3g, 4g; preferred: 2g
           |              current: allowed: 2g, 3g, 4g; preferred: 4g
  Bands    |            supported: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
           |                       eutran-5, eutran-7, eutran-8, eutran-20, eutran-38, eutran-40,
           |                       eutran-41
           |              current: egsm, dcs, utran-1, utran-5, utran-8, eutran-1, eutran-3,
           |                       eutran-41
  IP       |            supported: ipv4, ipv6, ipv4v6
  3GPP     |                 imei: 862348051548204
           |          operator id: 40402
           |        operator name: airtel
           |         registration: home
  3GPP EPS | ue mode of operation: csps-2
  SIM      |            dbus path: /org/freedesktop/ModemManager1/SIM/0
  Bearer   |            dbus path: /org/freedesktop/ModemManager1/Bearer/0
In the status it shows connected, however if I try ping with
apalis-imx8-06852506:~$ ping -I wwan0 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
I get no packets in return.
Can anyone guide me ahead of this or share any relevant resources. I am using Torizoncore on Apalix-IMX8QM.
Nikhil
Hi @hexagun,
After this I hope you have enabled radio and connected to cellular modem using below command
nmcli c add type gsm ifname ttyUSB0 con-name imx6 apn airtelgprs.com
nmcli r wwan on
# mmcli -m 0 --simple-connect="apn=airtelgprs.com"
successfully connected the modem
Also to further confirm check output of
apalis-imx6-04860438:~$ mmcli -b 0
  General            |  dbus path: /org/freedesktop/ModemManager1/Bearer/0
                     |       type: default
  Status             |  connected: yes
                     |  suspended: no
                     |  interface: wwan0
                     | ip timeout: 20
  Properties         |        apn: wap.airtel
                     |    roaming: allowed
  IPv4 configuration |     method: static
                     |    address: 100.78.10.239
                     |     prefix: 27
                     |    gateway: 100.78.10.225
                     |        dns: 117.96.122.40, 122.175.1.5
  Statistics         |   duration: 30
Let me know after this also you are facing same problem.
Thanks & Best Regards
Ritesh Kumar
The mention steps in Modem Support work well. The sim we were using had data balance issue which was sorted after which ping works.
Consider the issue solved.
Nikhil
