I have a SIM 868 module and I am trying to connect the iMX7 board to the internet using the module.
I am facing an issue during the connect command. The log shows that the connect script failed.
Have any one tried accessing gprs on toradex from SIM800 series modules?
Hi @imtanmayp
Most of the time the easiest solution is to use something like ModemManager. It should also work with ppp. You would have to follow this article:
And then that:
However, I’m not sure if it will work in the end. Here a list of some modems where we did some tests with:
Stefan
