Would it be possible to enable a confirmation dialog fot UpdateTool.exe or launcher.exe, before anything is done. (either updated or copied)?
The feature would preventing an unwanted files overwrite or image update, when a USB disk is inserted with autorun/autocopy folders on it (I admit. It has happen for me once or twice)
The feature could be enabled through some registry settings if they are needed.
@TJO,
We currently don’t plan to implement this feature for the launcher. However, I added it to our list and the feature request will be discussed in our next software development meeting. For the Update Tool, this should actually be the case unless you specified the command line switch to run in non-attended mode. If this isn’t the case, please let me know how you use the UpdateTool and which version. Thanks.
