Hi everyone,
I’m working with a Colibri iMX7 module (eMMC version) with Aster Carrier Board and attempting to configure SPI1 with two Chip Select (CS) pins using a custom device tree overlay. Specifically, I want to use the following configuration:
SPI1 Interface
CS0 assigned to SODIMM Pin 86
CS1 assigned to SODIMM Pin 79
I’ve created a device tree overlay file (imx7d-colibri-spi1-overlay.dts) to configure these CS pins, but I’m not entirely sure if the assignments and configuration are correct. Below is a simplified version of my device tree overlay:
/dts-v1/;
/plugin/;
compatible = "toradex,colibri-imx7";
fragment@0 {
target = <&ecspi1>;
__overlay__ {
/* Define the CS pins */
cs-gpios = <
&gpio3 6 GPIO_ACTIVE_LOW /* CS0: GPIO3_IO06 (SODIMM 86) */
&gpio2 23 GPIO_ACTIVE_LOW /* CS1: GPIO2_IO23 (SODIMM 79) */
num-cs = <2>;
/* Pin configuration for CS0 (SODIMM 86, GPIO3_IO06) */
fragment@1 {
target = <&iomuxc>;
__overlay__ {
pinctrl_ecspi1_cs0: ecspi1cs0grp {
fsl,pins = <
MX7D_PAD_SAI2_RX_SYNC__GPIO3_IO06 0x14 /* Correct for SODIMM 86 */
/* Pin configuration for CS1 (SODIMM 130, GPIO2_IO23) */
fragment@2 {
target = <&iomuxc>;
__overlay__ {
pinctrl_ecspi1_cs1: ecspi1cs1grp {
fsl,pins = <
MX7D_PAD_ENET2_RGMII_TX_CTL__GPIO2_IO23 0x14 /* Correct for SODIMM 130 */
/* Attach the pin configurations to ecspi1 */
fragment@3 {
target = <&ecspi1>;
__overlay__ {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_ecspi1_cs0 &pinctrl_ecspi1_cs1>;
My Questions:
- Does the above device tree overlay look correct for configuring SPI1 with
CS0onGPIO3_IO06(SODIMM 86) andCS1onGPIO2_IO23(SODIMM 79)? - Are there any specific considerations I should be aware of when configuring these GPIO pins for SPI on the Colibri iMX7?
- After applying the overlay and rebooting, what would be the best way to verify if the configuration is correct?
- If there are better practices for assigning multiple CS pins on SPI in this setup, I’d love to hear your suggestions!
Any advice, corrections, or pointers would be greatly appreciated!
Thanks in advance!
