Hello Toradex Support,
I’m using a Verdin iMX8M Mini SoM on an Ivy carrier board, and I want Yocto to automatically select the correct device tree (imx8mm-verdin-wifi-ivy.dtb) without having to stop at U-Boot and manually set fdtfile.
My current machine configuration is based on verdin-imx8mm.conf, with this :
#@TYPE: Machine
#@NAME: Toradex Verdin iMX8M Mini
#@SOC: i.MX8MM
#@DESCRIPTION: Machine configuration for Toradex Verdin iMX8M Mini SoM
#@MAINTAINER: Max Krummenacher <max.krummenacher@toradex.com>
MACHINE_NAME = "Verdin-iMX8MM"
MACHINEOVERRIDES =. "tdx:mx8:mx8m:mx8mm:"
MACHINE_EXTRA_RRECOMMENDS:append = " mwifiexconf"
IMX_DEFAULT_BSP = "nxp"
IMX_DEFAULT_BSP:upstream = "mainline"
require conf/machine/include/imx-base.inc
# override imx-base.inc which sets this to cortexa53-crypto
DEFAULTTUNE:mx8mm-generic-bsp = "armv8a-crypto"
require conf/machine/include/arm/armv8a/tune-cortexa53.inc
# Don't include kernels in standard images
RRECOMMENDS:${KERNEL_PACKAGE_NAME}-base = ""
KERNEL_DTB_PREFIX = "freescale/"
KERNEL_DEVICETREE = " \
${KERNEL_DTB_PREFIX}imx8mm-verdin-wifi-ivy.dtb \
KERNEL_IMAGETYPE:mx8-generic-bsp = "Image.gz"
UBOOT_CONFIG ??= "sd"
UBOOT_CONFIG[sd] = "verdin-imx8mm_defconfig,sdcard"
SPL_BINARY = "spl/u-boot-spl.bin"
UBOOT_DTB_LOADADDRESS:mx8mm-generic-bsp = "0x50200000"
UBOOT_DTBO_LOADADDRESS:mx8mm-generic-bsp = "0x50240000"
UBOOT_ENTRYPOINT:mx8mm-generic-bsp = "0x48200000"
UBOOT_RD_LOADADDRESS = "0x52300000"
# Set u-boot DTB
UBOOT_DTB_NAME = "imx8mm-verdin-wifi-dev.dtb"
# Set DDR FIRMWARE
DDR_FIRMWARE_NAME = " \
lpddr4_pmu_train_1d_imem.bin \
lpddr4_pmu_train_1d_dmem.bin \
lpddr4_pmu_train_2d_imem.bin \
lpddr4_pmu_train_2d_dmem.bin \
ATF_PLATFORM = "imx8mm"
SOC_ATF_BOOT_UART_BASE:verdin-imx8mm = "0x30860000"
BOOT_SPACE = "65536"
# Set imx-mkimage boot target
IMXBOOT_TARGETS = "flash_evk_emmc_fastboot"
IMX_BOOT_SOC_TARGET = "iMX8MM"
IMAGE_BOOT_FILES:append = " boot.scr-${MACHINE};boot.scr"
WKS_FILE_DEPENDS:append = " u-boot-default-script"
PREFERRED_PROVIDER_u-boot-default-script = "u-boot-distro-boot"
LOADADDR = ""
UBOOT_SUFFIX = "bin"
UBOOT_MAKE_TARGET = ""
IMX_BOOT_SEEK = "33"
SERIAL_CONSOLES = "115200;ttymxc0"
MACHINE_FEATURES += "3g bluetooth alsa ext2 pci screen touchscreen tpm2 usbgadget usbhost vfat wifi"
PREFERRED_PROVIDER_virtual/kernel = "linux-toradex"
PREFERRED_PROVIDER_virtual/kernel:preempt-rt = "linux-toradex"
PREFERRED_PROVIDER_virtual/kernel:use-mainline-bsp = "linux-toradex-upstream"
PREFERRED_VERSION_linux-toradex-upstream = "6.6%"
PREFERRED_PROVIDER_virtual/kernel:use-mainline-bsp:preempt-rt = "linux-toradex-upstream-rt"
PREFERRED_VERSION_linux-toradex-upstream-rt = "6.6%"
PREFERRED_PROVIDER_virtual/dtb:use-mainline-bsp = "device-tree-overlays-mainline"
PREFERRED_VERSION_linux-imx-headers = "6.6"
IMX_DEFAULT_BOOTLOADER = "u-boot-toradex"
# variables to control imx-boot with u-boot
ATF_LOAD_ADDR = "0x920000"
IMX_EXTRA_FIRMWARE = "firmware-imx-8m"
TEE_LOAD_ADDR = "0xbe000000"
UBOOT_MAKE_TARGET:use-mainline-bsp = "all"
# handle machine firmware
MACHINE_FIRMWARE:append = " linux-firmware-ath10k linux-firmware-imx-sdma-imx7d"
MACHINE_FIRMWARE:append = " linux-firmware-sd8997"
MACHINE_FIRMWARE:append = " firmware-imx-vpu-imx8"
BOARD_TYPE = "verdin"
IMAGE_CLASSES:append = " image_type_tezi"
IMAGE_FSTYPES += "teziimg"
UBOOT_BINARY_TEZI_EMMC = "imx-boot"
OFFSET_BOOTROM_PAYLOAD = "2"
TEZI_EXTERNAL_KERNEL_DEVICETREE_BOOT = "verdin-imx8mm_dsi-to-hdmi_overlay.dtbo verdin-imx8mm_spidev_overlay.dtbo"
TORADEX_PRODUCT_IDS = "0055 0057 0059 0060 0068 0086 0087 0090 0216"
TORADEX_PRODUCT_IDS[0055] = "imx8mm-verdin-wifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0057] = "imx8mm-verdin-nonwifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0059] = "imx8mm-verdin-nonwifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0060] = "imx8mm-verdin-wifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0068] = "imx8mm-verdin-wifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0086] = "imx8mm-verdin-nonwifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0087] = "imx8mm-verdin-nonwifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0090] = "imx8mm-verdin-wifi-v1.1-dev.dtb"
TORADEX_PRODUCT_IDS[0216] = "imx8mm-verdin-wifi-v1.1-dev.dtb"
From my understanding, TORADEX_PRODUCT_IDS is used by Toradex Easy Installer and U-Boot to select the right DTB for the detected hardware.
Could you clarify:
- What is the recommended way to set
TORADEX_PRODUCT_IDSso that the Ivy carrier board always boots withimx8mm-verdin-wifi-ivy.dtb? - Should all entries in
TORADEX_PRODUCT_IDSthat match my SoM SKU be mapped to the Ivy DTB, or is there a more targeted approach? - Do I also need to set
UBOOT_DTB_NAMEto the Ivy DTB to make this work in Yocto, or willTORADEX_PRODUCT_IDSalone override it?
My goal is to avoid manual setenv fdtfile in U-Boot and have the correct DTB applied automatically for the Ivy carrier board in all cases.
Thank you for your guidance!
Alvaro
