OS: linux
:: x64
:: WSL 2
Distro: Ubuntu 22.04.2 LTS
Extension activation logs:
Activating Torizon IDE ...
Telemetry is enabled
Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
Resolving host IP address ...
Host IP address OK
Docker installed OK
Docker running OK
Docker compose OK
PowerShell OK
git OK
dig OK
avahi-resolve OK
nmap OK
iputils-ping OK
file OK
sshpass OK
net-tools OK
Cloning project templates
Project templates clone OK
Checkout templates repo to v2.3.1 OK
Checking connected devices ...
Scanning Torizon devices ...
Configuring debug id_rsa ...
Debug id_rsa OK
Torizon IDE extension activated
Debian bookworm packages list load OK
ERROR :: build-configure-amd64-local failed with exit code 1
Tasks logs:
* Executing task: cmake -DCMAKE_BUILD_TYPE=Debug -B/home/osi/desarrollo/4dic2023/qt/build-local
-- The CXX compiler identification is GNU 11.4.0
-- The C compiler identification is GNU 11.4.0
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /usr/bin/c++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /usr/bin/cc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD
-- Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
-- Found Threads: TRUE
-- Performing Test HAVE_STDATOMIC
-- Performing Test HAVE_STDATOMIC - Success
-- Found WrapAtomic: TRUE
-- Could NOT find OpenGL (missing: OPENGL_INCLUDE_DIR)
-- Could NOT find WrapOpenGL (missing: WrapOpenGL_FOUND)
CMake Warning at /usr/lib/x86_64-linux-gnu/cmake/Qt6/Qt6Config.cmake:219 (find_package):
Found package configuration file:
/usr/lib/x86_64-linux-gnu/cmake/Qt6Gui/Qt6GuiConfig.cmake
but it set Qt6Gui_FOUND to FALSE so package "Qt6Gui" is considered to be
NOT FOUND. Reason given by package:
Qt6Gui could not be found because dependency WrapOpenGL could not be found.
Call Stack (most recent call first):
CMakeLists.txt:6 (find_package)
CMake Warning at /usr/share/cmake-3.22/Modules/CMakeFindDependencyMacro.cmake:47 (find_package):
/usr/lib/x86_64-linux-gnu/cmake/Qt6/QtPublicDependencyHelpers.cmake:14 (find_dependency)
/usr/lib/x86_64-linux-gnu/cmake/Qt6Quick/Qt6QuickDependencies.cmake:96 (_qt_internal_find_dependencies)
/usr/lib/x86_64-linux-gnu/cmake/Qt6Quick/Qt6QuickConfig.cmake:50 (include)
but it set Qt6Quick_FOUND to FALSE so package "Qt6Quick" is considered to
be NOT FOUND. Reason given by package:
Qt6Quick could not be found because dependency Qt6Gui could not be found.
CMake Error at CMakeLists.txt:6 (find_package):
but it set Qt6_FOUND to FALSE so package "Qt6" is considered to be NOT
Failed to find Qt component "Gui".
Expected Config file at
"/usr/lib/x86_64-linux-gnu/cmake/Qt6Gui/Qt6GuiConfig.cmake" exists
Failed to find Qt component "Quick".
"/usr/lib/x86_64-linux-gnu/cmake/Qt6Quick/Qt6QuickConfig.cmake" exists
-- Configuring incomplete, errors occurred!
See also "/home/osi/desarrollo/4dic2023/qt/build-local/CMakeFiles/CMakeOutput.log".
* The terminal process "/usr/bin/bash '-c', 'cmake -DCMAKE_BUILD_TYPE=Debug -B/home/osi/desarrollo/4dic2023/qt/build-local'" terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
