[-- Configuring incomplete, errors occurred!] - 🤖 VS Code IDE Extension Issue Report (01933330f24d6de5369d5c76b07cb99d)
OS: linux :: x64 :: WSL 2
Distro: Ubuntu 20.04.6 LTS
Extension activation logs:
 Activating Torizon IDE ...
 Telemetry is enabled
 Extension collects completely anonymous telemetry data about templates usage. Participation in this anonymous program is optional, and you may opt-out if you'd not like to share any information. Check: https://github.com/toradex/torizon-experimental-torizon-ide-v2-docs/blob/main/USAGE-DATA.md#opt-out
 Telemetry allows us to accurately gauge templates usage. This data will help us to focus better on the most used templates, adding new features and putting effort in the right place.
 Resolving host IP address ...
 Host IP address OK
 Docker installed OK
 Docker running OK
 Docker compose OK
 PowerShell OK
 git OK
 dig OK
[11-30 23:47:21.01] avahi-resolve OK
 nmap OK
 iputils-ping OK
 file OK
 sshpass OK
 net-tools OK
 Cloning project templates
 Project templates clone OK
 Checkout templates repo to v2.3.1 OK
 Checking connected devices ...
 Scanning Torizon devices ...
 Configuring debug id_rsa ...
 Debug id_rsa OK
 Torizon IDE extension activated
 Checking host ip sanity ...
 Debian bookworm packages list load OK
[11-30 23:47:44.08] Host ip has been updated OK
 Device 192.168.1.7 set as Docker Host
 ERROR :: check-deps failed with exit code 69
 ERROR :: build-configure-amd64-local failed with exit code 1
Tasks logs:
Container Runtime: docker
Run Arguments: -d -p 5002:5000 --restart=always registry:2
Container Name: registry
Error response from daemon: No such container: registry
Container does not exists. Starting ...
Unable to find image 'registry:2' locally
2: Pulling from library/registry
96526aa774ef: Pull complete
834bccaa730c: Pull complete
87a69098c0a9: Pull complete
afc17120a9f7: Pull complete
e5ac04f3acf5: Pull complete
Digest: sha256:8a60daaa55ab0df4607c4d8625b96b97b06fd2e6ca8528275472963c4ae8afa0
Status: Downloaded newer image for registry:2
19ee649da08a7891cd7bfb86c86d17434dd6029ce6eb82930a6a975d9389fb83
 *  Executing task: cmake -DCMAKE_BUILD_TYPE=Debug -B/home/oubay/QuetoOubay/build-local
-- The CXX compiler identification is GNU 9.4.0
-- The C compiler identification is GNU 9.4.0
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
CMake Error at CMakeLists.txt:6 (find_package):
  By not providing "FindQt6.cmake" in CMAKE_MODULE_PATH this project has
  asked CMake to find a package configuration file provided by "Qt6", but
  CMake did not find one.
  Could not find a package configuration file provided by "Qt6" with any of
  the following names:
    Qt6Config.cmake
    qt6-config.cmake
  Add the installation prefix of "Qt6" to CMAKE_PREFIX_PATH or set "Qt6_DIR"
  to a directory containing one of the above files.  If "Qt6" provides a
  separate development package or SDK, be sure it has been installed.
See also "/home/oubay/QuetoOubay/build-local/CMakeFiles/CMakeOutput.log".
 *  The terminal process "/usr/bin/bash '-c', 'cmake -DCMAKE_BUILD_TYPE=Debug -B/home/oubay/QuetoOubay/build-local'" terminated with exit code: 1.
    Qt6Config.cmake
    qt6-config.cmake
Reported by: @undefined
If you have more data that you think that is interesting from the context of the issue please reply below.
Thanks :robot:
First of all it seems for whatever reason cmake failed to configure your project. It’s hard to say what exactly without seeing the relevant cmake files
Second, you seem to be running the task for building this for amd64 instead of arm32/arm64. Did you mistakenly target the wrong platform when building your project?
