the --volume option seems not enough to dynamically mount and unmount USB drives and sticks in a docker containers when they are physically plugged and unplugged as mentioned here on serverfault.com. Therefore it is possible to do that using the more powerful --mount option this way:
docker run --rm -it --privileged --mount type=bind,source=/var/rootdirs/media,target=/disks,bind-propagation=shared torizon/debian:$CT_TAG_DEBIAN /bin/bash
Unfortunately I am not able to configure that option in VS Code. On February I asked an other question about other simpler docker options and the answer was general enough to solve similar issues, but now I am blocked again because the option argument is more complex, being a list of Mounts objects, according to the documentation (link).
Some unsuccessful attempts results in similar config.yaml
to accomplish what i’m after requires an entry under “extraparams”.
In VSCode, when i go to Configurations-extraparams, i’m propmted for a ‘key’ then a ‘Value’. Same with Configurations-Volumes, i’m propmted for a ‘key’ then a ‘value’
Dear Jeremias,
the described method helped me to see the flash drive, but it is connected only with “root” rights and therefore I cannot write to it. Can you advise me how to get the right one for the “user”? Thank you
Dear Henrique,
I have TorizonCore 5.7.0+build.17, I use VS Code with the Toradex Extension and I found that the propagation: “shared” flag from config.yaml is not propagated to the resulting config.v2.json in the appropriate container.
