I need to configure yocto to build imx-boot with ahab enable for the board colibri imx8x.
Could you help me ?.
Thank you
Best regards.
Flavio Gobber
Thank you
Best regards.
Flavio Gobber
To enable AHAB (Advanced High Assurance Boot) for the Colibri iMX8X in Yocto, you’ll need to modify the U-Boot configuration and use Toradex’s security meta-layer(1).
First, you need to enable AHAB support in the U-Boot configuration(2). The default configuration doesn’t have AHAB enabled, so you’ll need to modify the config:
→ ARM architecture
[*] Support i.MX8 AHAB features
Toradex provides a dedicated meta-layer for security features including HAB/AHAB support(1). You should include the meta-toradex-security layer in your Yocto build(1).
The security layer includes variables to configure HAB/AHAB support. When the tdx-signed class is inherited, signing bootloader images via HAB/AHAB is enabled by default.
For the Colibri iMX8X, you’ll need to build the complete boot container that includes(3):
The boot container assembly process uses the imx-mkimage utility(3). For Colibri iMX8X, the build command would be(3):
$ make REV=C0 SOC=iMX8QX flash
$ ls iMX8QX/flash.bin
Note: Remove REV=C0 if you’re building for B0 or older silicon versions(3).
Before proceeding, ensure you have(3):
The resulting flash.bin file should be renamed to imx-boot for compatibility with Toradex Easy Installer(3).
For detailed implementation, I recommend reviewing the meta-toradex-security repository documentation for the specific configuration variables and setup procedures(1).
