I don’t have specific information about configuring single-antenna scenarios during the TorizonCore Builder build process in the available sources. However, I can provide you with an approach to achieve this configuration.
Approach: Capture Configuration Changes
Based on the TorizonCore Builder workflow, you can configure your Torizon OS for single-antenna scenario by capturing the configuration changes after applying them manually, then including those changes in your custom image build.
Steps to Configure Single-Antenna with TorizonCore Builder:
Apply Single-Antenna Configuration Manually
- First, configure your device for single-antenna mode following the runtime configuration steps you referenced
- Make the necessary changes to your running Torizon OS device
Capture the Configuration Changes
- Use the
isolate command to capture all configuration changes from your device(1):
$ torizoncore-builder isolate --remote-host <board_ip> --remote-username <username> --remote-password <password> --changes-directory changes1
(1)
- Include Changes in Your Custom Image Build
- Create a configuration file (
tcbuild.yaml) that includes your captured changes(1):
# Sample configuration file:
input:
easy-installer:
local: images/torizon-core-docker-<your-module>-Tezi_<version>.tar
# Include the captured configuration changes
customization:
filesystem:
- changes1/
output:
easy-installer:
local: torizon-core-docker-<your-module>-Tezi_<version>.CUSTOM
(1)
- Build Your Custom Image
- Run the build command to generate your custom image(1):
$ torizoncore-builder build
(1)
Why This Approach Works
The isolate command captures all configuration changes made to the /etc directory of your board, including modifications, additions, deletions, and file/directory permissions and ownership(1). This method is specifically designed for capturing system configuration changes that need to be committed to the Torizon OS image(1).
TorizonCore Builder supports capturing device configuration as one of its key features, allowing you to preserve configuration changes made to a target device at runtime during development and embed them into your final OS image(2).
