Hello Toradex team,
I hope you are all doing great! And thank you for your support.
Hardware:
- SoM Verdin IMX8M Plus Quad 4GB WB IT v1.1A
- Heatsink Verdin Industrial Heatsink Type 1 V1.0B
- Dual-Band Wi-Fi/Bluetooth PCB Antenna 100mm V1.0A
- Custom Carrier Board based on Verdin
uname:
- Linux verdin-imx8mp-14777482 5.15.129-6.4.0+git.67c3153d20ff #1-TorizonCore SMP PREEMPT Wed Sep 27 12:30:36 UTC 2023 aarch64 aarch64 aarch64 GNU/Linux
Images tested:
- torizon-core-docker-verdin-imx8mp-Tezi_6.4.0+build.5.tar (STABLE Release)
Guest OS:
- macOS (M1 Pro ARM64)
- Linux ubuntu (VM x86_64)
Issue:
We are using the beta feature remote-access to be able to debug our hardware on the fly. The service works great but there is a lack of customization. We realize that the service itself use a lots of data (you can see the log of
2024.01.23.11.02 - WireShark Remote access only.csv (192.5 KB)) and we don’t have the possibility to tweak some parameters.
So my question is the following, is there the possibility to change some parameters to reduce the amount of ping (~3 seconds) to something more realistic that fit the limited constraint of a cellular connection ? I realize that the experience will not be the same but that something we are ready to sacrifice.
M
