Hi
I updated a VF50 with the latest 1.7 version. The module version is 1.2B.
I set the boot loader countdown to 5 seconds and save the config. Boot into CE80 and verify it with config block editor.
But when I restart the module countdown is 30 seconds again??
Command for setting the value
>set boot.delay 5
>save boot
Finding bootargs block...
Writing 5 sector(s) of bootargs data from sector 320.
>setconfig boot
boot.delay: 5 (User key press delay)
After restart:
Toradex Bootloader 1.7 for Vybrid Built May 1 2020
Colibri VF50 128MB
Invalid config block data
CPU : 400 Mhz
Flash: 128 MB
RAM : 128 MB
Static config block is not valid!
Invalid temp static config block checksum on byte 0
Error restoring static config block.
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 20 seconds.
