We were previously using 2.4 based BSP with V1.0B modules. Because of the fast boot mode enabled in V1.1A modules, I have updated our u-boot to V2.6 to support this. However when I update the bootloader to the new version, the config block is lost.
I can restore it using cfgblock create in u-boot, but this is not desired for automatic programming in production because of manually entering serial number.
The V1.0B modules have bootloader version U-Boot 2015.04 (May 18 2015 - 14:17:54) installed.
After running setupdate, my environment is as follows:
Colibri iMX6 # run setupdate
MMC: no card present
** Bad device mmc 1 **
starting USB...
USB0: Port not available.
USB1: USB EHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
scanning usb for ethernet devices... 0 Ethernet Device(s) found
** Bad device usb 0 **
Using FEC device
TFTP from server 192.168.1.61; our IP address is 192.168.1.51
Filename 'flash_eth.img'.
Load address: 0x10800000
Loading: #
1.8 MiB/s
done
Bytes transferred = 3720 (e88 hex)
## Executing script at 10800000
enter "run update" to update the entire module
Colibri iMX6 # printenv
arch=arm
baudrate=115200
board=colibri_imx6
board_name=colibri_imx6
board_rev=010b
boot_file=uImage
bootcmd=run emmcboot ; echo ; echo emmcboot failed ; run nfsboot ; echo ; echo nfsboot failed ; usb start ;setenv stdout serial,vga ; setenv stdin serial,usbkbd
bootdelay=1
check_1=setenv conf_blk_offset 0x1fff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_2=setenv conf_blk_offset 0xfff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_3=setenv conf_blk_offset 0x7ff; mmc read ${loadaddr} ${conf_blk_offset} 1
check_configblock=setexpr toradex_oui_addr ${loadaddr} + 8; mw.l ${kernel_addr_r} 0x002d1400; mmc dev 0 1; run check_1 || run check_2 || run check_3; cmp.b ${kernel_addr_r} ${toradex_oui_addr} 3
console=ttymxc0
cp_file_chunk=tftpboot ${loadaddr} ${board_name}/root.ext3-${filenum}; run set_blkcnt; mmc dev 0 0 && mmc write ${loadaddr} ${blkstart} ${blkcnt}
cpu=armv7
defargs=enable_wait_mode=off galcore.contiguousSize=50331648
dfu_alt_info=u-boot.imx raw 0x2 0x3ff mmcpart 0;boot part 0 1;rootfs part 0 2;uImage fat 0 1;imx6q-colibri-eval-v3.dtb fat 0 1;imx6q-colibri-cam-eval-v3.dtb fat 0 1
drive=0
echo_migrate=echo successfully updated U-Boot, power-cycle and enter \\"run setupdate\\; run migrate\\" to complete update
emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 rootwait
emmcboot=run setup; setenv bootargs ${defargs} ${emmcargs} ${setupargs} ${vidargs}; echo Booting from internal eMMC chip...; run emmcdtbload; load mmc 0:1 ${kernel_addr_r} ${boot_file} && bootm ${kernel_addr_r} ${dtbparam}
emmcdtbload=setenv dtbparam; load mmc 0:1 ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
ethact=FEC
ethaddr=00:14:2d:4b:75:75
ethprime=FEC
fdt_addr_r=0x12000000
fdt_file=imx6dl-colibri-eval-v3.dtb
fileaddr=10800000
filesize=e88
incr_decimal=setexpr filenum ${filenum} + 1; setexpr filenrlow ${filenum} % 0x10; test ${filenrlow} -eq "a" && setexpr filenum ${filenum} + 0x6; true
interface=usb
ipaddr=192.168.1.51
kernel_addr_r=0x10800000
loadaddr=0x12000000
migrate=run migrate_configblock; run update_latest; reset
migrate_configblock=run check_configblock; mmc dev 0 0 && mmc read ${loadaddr} 0x500 1 && cmp.b ${kernel_addr_r} ${toradex_oui_addr} 3 && mmc dev 0 1 && mmc write ${loadaddr} ${conf_blk_offset} 1
migrate_uboot=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 1 && mmc write ${loadaddr} 2 ${blkcnt} && patch_ddr_size && mmc bootbus 0 2 1 2 && mmc partconf 0 1 1 0
migrate_uboot_old=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 0 && mmc write ${loadaddr} 2 ${blkcnt}; patch_ddr_size
netmask=255.255.255.0
nfsargs=ip=:::::eth0:on root=/dev/nfs rw netdevwait
nfsboot=run setup; setenv bootargs ${defargs} ${nfsargs} ${setupargs} ${vidargs}; echo Booting via DHCP/TFTP/NFS...; run nfsdtbload; dhcp ${kernel_addr_r} && bootm ${kernel_addr_r} ${dtbparam}
nfsdtbload=setenv dtbparam; tftp ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
ramdisk_addr_r=0x12100000
sdargs=ip=off root=/dev/mmcblk1p2 rw,noatime rootfstype=ext3 rootwait
sdboot=run setup; setenv bootargs ${defargs} ${sdargs} ${setupargs} ${vidargs}; echo Booting from SD card in 8bit slot...; run sddtbload; load mmc 1:1 ${kernel_addr_r} ${boot_file} && bootm ${kernel_addr_r} ${dtbparam}
sddtbload=setenv dtbparam; load mmc 1:1 ${fdt_addr_r} ${fdt_file} && setenv dtbparam " - ${fdt_addr_r}" && true
serial#=04945269
serverip=192.168.1.61
set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
set_nextnum=run incr_decimal; setexpr blkstart ${blkstart} + ${blkcnt}
setethupdate=tftpboot ${kernel_addr_r} flash_eth.img
setsdupdate=setenv interface mmc; setenv drive 1; mmc rescan; load ${interface} ${drive}:1 ${kernel_addr_r} flash_blk.img
setup=setenv setupargs fec_mac=${ethaddr} consoleblank=0 no_console_suspend=1 console=tty1 console=${console},${baudrate}n8
setupdate=run setsdupdate || run setusbupdate || run setethupdate; source ${kernel_addr_r}
setusbupdate=usb start && setenv interface usb; setenv drive 0; load ${interface} ${drive}:1 ${kernel_addr_r} flash_blk.img
soc=mx6
splashpos=m,m
update=mmc bootbus 0 2 0 1 && run update_new && exit; run update_v2.4b1
update_1=tftpboot ${loadaddr} ${board_name}/mbr.bin && mmc dev 0 0 && mmc write ${loadaddr} 0x0 0x1
update_2=tftpboot ${loadaddr} ${board_name}/boot.vfat && run set_blkcnt && mmc dev 0 0 && mmc write ${loadaddr} 0x2000 ${blkcnt}
update_3=setenv filesize 4000000; setenv filenum 10; setenv blkstart a000; while test ${filesize} -eq "4000000"; do run cp_file_chunk; run set_nextnum; done; true
update_configblock=run check_configblock; tftpboot ${loadaddr} ${board_name}/configblock.bin && mmc dev 0 1 && mmc write ${loadaddr} ${conf_blk_offset} 1
update_fdt=tftpboot ${loadaddr} ${board_name}/${fdt_file} && fatwrite mmc 0:1 ${loadaddr} ${fdt_file} ${filesize}
update_kernel=tftpboot ${loadaddr} ${board_name}/uImage && fatwrite mmc 0:1 ${loadaddr} uImage ${filesize}
update_latest=run update_uboot; run update_1; run update_2; run update_kernel; run update_fdt; run update_3
update_new=updt_fuse -n && run update_latest && reset; run update_v2.5b3
update_uboot=tftpboot ${loadaddr} ${board_name}/u-boot.imx && run set_blkcnt && mmc dev 0 1 && mmc write ${loadaddr} 2 ${blkcnt} && patch_ddr_size && updt_fuse && mmc bootbus 0 2 0 1 && mmc partconf 0 1 1 0 && mmc rst-function 0 1
update_v2.4b1=run check_configblock || run migrate_configblock; run migrate_uboot_old && run echo_migrate
update_v2.5b3=run check_configblock || run migrate_configblock; run migrate_uboot && run echo_migrate
vendor=toradex
ver=U-Boot 2015.04 (May 18 2015 - 14:17:54)
vidargs=video=mxcfb0:dev=lcd,640x480M@60,if=RGB666 video=mxcfb1:off fbmem=8M
Environment size: 5882/8188 bytes
I now run update:
Colibri iMX6 # run update
mmc - MMC sub system
Usage:
mmc info - display info of the current MMC device
mmc read addr blk# cnt
mmc write addr blk# cnt
mmc erase blk# cnt
mmc rescan
mmc part - lists available partition on current mmc device
mmc dev [dev] [part] - show or set current mmc device [partition]
mmc list - lists available devices
mmc hwpartition [args...] - does hardware partitioning
arguments (sizes in 512-byte blocks):
[user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
[gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
[check|set|complete] - mode, complete set partitioning completed
WARNING: Partitioning is a write-once setting once it is set to complete.
Power cycling is required to initialize partitions after set to complete.
mmc setdsr <value> - set DSR register value
switch to partitions #1, OK
mmc0(part 1) is current device
MMC read: dev # 0, block # 8191, count 1 ... MMC: block number 0x2000 exceeds max(0x1000)
0 blocks read: ERROR
MMC read: dev # 0, block # 4095, count 1 ... 1 blocks read: OK
byte at 0x10800001 (0x14) != byte at 0x12000009 (0x0)
Total of 1 byte(s) were the same
switch to partitions #0, OK
MMC read: dev # 0, block # 1280, count 1 ... 1 blocks read: OK
byte at 0x10800000 (0x0) != byte at 0x12000008 (0x1)
Total of 0 byte(s) were the same
Using FEC device
Filename 'colibri_imx6/u-boot.imx'.
Load address: 0x12000000
Loading: ######################
4.8 MiB/s
done
Bytes transferred = 314368 (4cc00 hex)
MMC write: dev # 0, block # 2, count 614 ... 614 blocks written: OK
done.
successfully updated U-Boot, power-cycle and enter "run setupdate; run migrate" to complete update
Colibri iMX6 #
As you can see, there is an error when trying to read the MMC.
I power-cycle the target and run setupdate and migrate:
U-Boot 2015.04 (Oct 06 2017 - 11:23:46)
CPU: Freescale i.MX6SOLO rev1.2 at 792 MHz
CPU: Temperature 61 C
Reset cause: POR
I2C: ready
DRAM: 256 MiB
PMIC: device id: 0x10, revision id: 0x21
PMIC: programmed
MMC: FSL_SDHC: 0, FSL_SDHC: 1
*** Warning - bad CRC, using default environment
auto-detected panel vga-rgb
Display: vga-rgb (640x480)
In: serial
Out: serial
Err: serial
Missing Toradex config block
Model: Toradex Colibri iMX6 256MB
Net: using PHY at 0
FEC [PRIME]
Error: FEC address not set.
Normal Boot
starting USB...
USB1: USB EHCI 1.00
Using FEC device
Loading: ################################################## 3.6 KiB
605.5 KiB/s
done
## Executing script at 12000000
Colibri iMX6 # run migrate
byte at 0x11000001 (0x14) != byte at 0x12000009 (0x0)
byte at 0x11000000 (0x0) != byte at 0x12000008 (0x1)
Using FEC device
Loading: ################################################## 307 KiB
8.3 MiB/s
done
done.
Fuse 0, 5: 5062
Warning: Programming fuses is an irreversible operation!
Updating to fast boot mode prevents easy
downgrading to previous BSP versions.
Really perform this fuse programming? <y/N>
y
Fusing fast boot mode...
done.
Using FEC device
Filename 'colibri_imx6/mbr.bin'.
Loading: ################################################## 512 Bytes
83 KiB/s
done
Bytes transferred = 512 (200 hex)
MMC write: dev # 0, block # 0, count 1 ... 1 blocks written: OK
Using FEC device
Filename 'colibri_imx6/boot.vfat'.
Loading: ################################################## 16 MiB
9.6 MiB/s
done
Bytes transferred = 16777216 (1000000 hex)
MMC write: dev # 0, block # 8192, count 32768 ... 32768 blocks written: OK
Using FEC device
Filename 'colibri_imx6/uImage'.
Loading: ################################################## 4.2 MiB
9.6 MiB/s
done
Bytes transferred = 4408160 (434360 hex)
writing uImage
4408160 bytes written
Using FEC device
Filename 'colibri_imx6/imx6dl-colibri-eval-v3.dtb'.
Loading: ################################################## 50.7 KiB
4.5 MiB/s
done
Bytes transferred = 51925 (cad5 hex)
writing imx6dl-colibri-eval-v3.dtb
51925 bytes written
Using FEC device
Filename 'colibri_imx6/root.ext3-10'.
Loading: ################################################## 64 MiB
9.6 MiB/s
done
Bytes transferred = 67108864 (4000000 hex)
MMC write: dev # 0, block # 40960, count 131072 ... 131072 blocks written: OK
Using FEC device
Filename 'colibri_imx6/root.ext3-11'.
9.6 MiB/s
done
MMC write: dev # 0, block # 172032, count 131072 ... 131072 blocks written: OK
Using FEC device
Filename 'colibri_imx6/root.ext3-12'.
9.6 MiB/s
done
MMC write: dev # 0, block # 303104, count 131072 ... 131072 blocks written: OK
Using FEC device
Filename 'colibri_imx6/root.ext3-13'.
Loading: ################################################## 13 MiB
9.6 MiB/s
done
Bytes transferred = 13631488 (d00000 hex)
MMC write: dev # 0, block # 434176, count 26624 ... 26624 blocks written: OK
resetting ...
CPU: Temperature 66 C
Reset cause: WDOG
I2C: ready
DRAM: 256 MiB
PMIC: programmed
In: serial
Out: serial
Err: serial
Net: using PHY at 0
FEC [PRIME]
Normal Boot
Colibri iMX6 #
As you can see, after run migrate, the module is updated. However the config block can no longer be read. What am I doing wrong?
Kind regards, Mark
