This is an odd one. I have a compose file: docker_web.yml (424 Bytes)
it launches 2 containers. a Server and a Client. I’ve run this on 2 machines.
a PC running Ubuntu WSL. and it works just fine.
Ran it on Verdin SoM from you guys. and I get an error
WebSocket connection to ‘ws://localhost:3001/ws’ failed:
What could be going on that one system works well, but the other can’t connect to the server.
The docker container were build for both platforms. Do I need something extra for the torizon OS?
Based on the context provided, there are several potential reasons why the WebSocket connection is failing on the Verdin SoM but working on a PC running Ubuntu WSL:
Network Configuration Differences: On the Verdin SoM, localhost refers to the container itself, not the host machine. This means that when the client tries to connect to ws://localhost:3001/ws, it may not be reaching the server container. You should try using the actual IP address of the server container or the host’s IP address in your WebSocket URL instead of localhost.
Server Not Running or Misconfigured: Ensure that the WebSocket server is running and listening on port 3001 within the Verdin SoM environment. Check the server logs for any issues during startup that might prevent it from running correctly.
Firewall or Security Settings: The Verdin SoM might have firewall settings or security configurations that block WebSocket connections. Make sure that the necessary ports are open and accessible.
Docker Networking Mode: Verify that the Docker containers are correctly networked. If they are not on the same network or if the network mode is not set correctly, it may prevent the client from connecting to the server. Consider using the host network mode if necessary.
Platform-Specific Dependencies: Ensure there are no architecture-specific dependencies or configurations affecting the WebSocket server’s operation on Torizon OS. Differences in service management or startup between Torizon OS and Ubuntu WSL could also contribute to the issue.
To resolve the issue, you should check these aspects and consider using the actual IP address instead of localhost in your WebSocket connection string. Additionally, reviewing the logs of both the server and client containers may provide further insights into the connection failure.
“webServer” is actually “webserver” if you want to try it out. I typed it in wrong. so we hardcoded “webserver” and in the compose I actually do have “webserver” so they match.
I was looking at this again and have some thoughts. Assuming that the websocket connection is only needed from your “client” service, then you can simplify your docker-compose. You don’t need to explicitly map a port in this case since docker-compose will automatically setup an internal network for your containers with DNS setup so that you can access them by the service name. ie the client container can access the api container using the domain name of “api”.
Mapping the port exposes it to the host so that the host can access it but if that is not needed I suggest removing it. Also, the way you have it specified (ie without a specific network IP address such as 127.0.0.1:3001) it is available on all network interfaces of your host. And if you happen to have a network firewall setup with iptables, docker will actually poke a hole in your firewall for that port.
Assuming you do not want that you can simplify your yml file as follows:
