Compiling the system with qtwebengine
hello everyone, i cant compile when i add the qtwebengine..
help me.
[image]
Qt_UTILS= "
qtwebview
qtwebsockets
qtwebkit
qtwebengine
qtvirtualkeyboard
qttools
qtsystems
qtsensors
qtserialport
qtquickcontrols
qtquickcontrols2
qtlocation
qtimageformats
qtdeclarative
qtbase
error (45.7 KB)
The secret to happiness in life is never use Qt for anything.
Judging from your error message alone
| In file included from /usr/include/c++/7/list:60:0,
|                  from ../../../../git/src/3rdparty/chromium/v8/src/torque/cfg.h:8,
|                  from ./../../../../git/src/3rdparty/chromium/v8/src/torque/cfg.cc:5,
|                  from v8_snapshot/gen/v8/torque_base_jumbo_1.cc:5:
| /usr/include/c++/7/bits/stl_algobase.h:59:10: fatal error: bits/c++config.h: No such file or directory
|  #include <bits/c++config.h>
| compilation terminated.
The Google chromium libraries have 32-bit components
OR
the default recipe assumes a 32-bit target and you need to tweak the recipe to force 64-bit build.
I realize the links I provided aren’t for embedded building but they identify what the problem is.
Hope this helps
Hi @AlanM ,
How exactly are you building this image? Which BSP version are you trying to build?
Can you please try to follow this article and build the tdx-reference-multimedia-image? This image already builds the QtWebEngine by default.
Daniel Morais
thanks, but not run. :frowning:
hello this is my information:
Build Configuration:
BB_VERSION = “1.46.0”
BUILD_SYS = “x86_64-linux”
NATIVELSBSTRING = “universal”
TARGET_SYS = “arm-tdx-linux-gnueabi”
MACHINE = “apalis-tk1”
DISTRO = “tdx-xwayland”
DISTRO_VERSION = “5.7.0-devel-20220915203844+build.0”
TUNE_FEATURES = “arm armv7a vfp thumb neon callconvention-hard”
TARGET_FPU = “hard”
meta-toradex-nxp = “HEAD:ee63c90fde9fde0229bff9ac1c5cffe356fc4f41”
meta-freescale = “HEAD:3cb29cff92568ea835ef070490f185349d712837”
meta-freescale-3rdparty = “HEAD:c52f64973cd4043a5e8be1c7e29bb9690eb4c3e5”
meta-toradex-tegra = “HEAD:f5753af4a5b9d33f0f474b320a74c2e29a66ec39”
meta-toradex-bsp-common = “HEAD:029a663150449a5e71b84dd4000476754d525c8c”
meta-oe
meta-filesystems
meta-gnome
meta-xfce
meta-initramfs
meta-networking
meta-multimedia
meta-python = “HEAD:8ff12bfffcf0840d5518788a53d88d708ad3aae0”
meta-freescale-distro = “HEAD:5d882cdf079b3bde0bd9869ce3ca3db411acbf3b”
meta-toradex-demos = “HEAD:ce3c1925df34b4d299b2dd1003ced41b9485ce41”
meta-qt5 = “HEAD:5ef3a0ffd3324937252790266e2b2e64d33ef34f”
meta-toradex-distro = “HEAD:cbde0286cb85bc445e70210b8df38f29b4784c08”
meta-poky = “HEAD:7e0063a8546250c4c5b9454cfa89fff451a280ee”
meta = “HEAD:add860e1a69f848097bbc511137a62d5746e5019”
meta-python2 = “dunfell:b901080cf57d9a7f5476ab4d96e56c30db8170a8”
meta-mono = “dunfell:517c45026dedfcfc7d8ac16e3f56b895942092ce”
meta-qt4 = “master:6d501ee2b4c5e2042823c09b1de5f08054132b43”
meta-java = “dunfell:3af889e112ddb5c677990535b1e0209c08f68e3f”
Hi @AlanM ,
Sorry, I didn’t understand what went wrong, following the steps here, did you have the same error as before while executing bitbake tdx-reference-multimedia-image?
Daniel Morais
hello i execute :frowning:
bitbake -k tdx-reference-multimedia-image
Hi @AlanM,
I made a small test on my side, and following the steps here I was able to build the tdx-reference-multimedia for Apalis TK1.
Can you please try again and check if you face the same issues? If yes, can you try to execute bitbake qtwebengine -c cleanall and build again?
Daniel Morais
