I am unable to understand the tutorial next steps.
Compile the kernel image according to the article quoted above.
Prepare an SD card and update your module as described in the articles below (according to the module of interest):
Flashing Embedded Linux to iMX7 Modules is not applicable for legacy scripts.
So i have to update using Toradex Easy Installer.
You likely flashed a new image to a module which changes the ‘host key’. So there is no evil attack on you.
Execute the proposed command to remove the conflicting host key from your local known_hosts file.
I cannot see anything wrong.
The ‘/’ directory is in texts usually referred to as ‘root directory’, ‘root directory’ does NOT mean a directory with the name root.
While including my toradex.bmp file for splash screen. I am getting the following error.
ezytech1@ezytech1-desktop:~/u-boot-toradex$ make -j3 2>&1 | tee build.log
CHK include/config/uboot.release
CHK include/generated/timestamp_autogenerated.h
UPD include/generated/timestamp_autogenerated.h
CHK include/generated/version_autogenerated.h
CHK include/generated/generic-asm-offsets.h
CHK include/generated/asm-offsets.h
HOSTCC tools/mkenvimage.o
HOSTCC tools/fit_image.o
HOSTCC tools/image-host.o
HOSTCC tools/dumpimage.o
HOSTCC tools/mkimage.o
tools/bmp_logo --gen-info ./tools/logos/toradex.bmp > include/bmp_logo.h
ERROR: Input file is not a bitmap
tools/Makefile:252: recipe for target 'include/bmp_logo.h' failed
make[1]: *** [include/bmp_logo.h] Error 1
make[1]: *** Waiting for unfinished jobs....
Makefile:1233: recipe for target 'tools' failed
make: *** [tools] Error 2
and when i removed that toradex.bmp from that location
/u-boot-toradex/tools/logos$
HOSTLD tools/mkenvimage
HOSTLD tools/dumpimage
HOSTLD tools/mkimage
CC cmd/version.o
CC common/main.o
LD cmd/built-in.o
CC common/board_f.o
LD common/built-in.o
CC drivers/video/cfb_console.o
drivers/video/cfb_console.c:165:27: error: 'BMP_LOGO_HEIGHT' undeclared here (not in a function)
#define VIDEO_LOGO_HEIGHT BMP_LOGO_HEIGHT
drivers/video/cfb_console.c:247:32: note: in expansion of macro 'VIDEO_LOGO_HEIGHT'
static int video_logo_height = VIDEO_LOGO_HEIGHT;
drivers/video/cfb_console.c: In function 'plot_logo_or_black':
drivers/video/cfb_console.c:164:26: error: 'BMP_LOGO_WIDTH' undeclared (first use in this function)
#define VIDEO_LOGO_WIDTH BMP_LOGO_WIDTH
drivers/video/cfb_console.c:1736:30: note: in expansion of macro 'VIDEO_LOGO_WIDTH'
int skip = VIDEO_LINE_LEN - VIDEO_LOGO_WIDTH * VIDEO_PIXEL_SIZE;
drivers/video/cfb_console.c:164:26: note: each undeclared identifier is reported only once for each function it appears in
drivers/video/cfb_console.c:1757:11: error: 'bmp_logo_bitmap' undeclared (first use in this function)
source = bmp_logo_bitmap;
drivers/video/cfb_console.c:1760:20: error: 'BMP_LOGO_COLORS' undeclared (first use in this function)
logo_red = malloc(BMP_LOGO_COLORS);
drivers/video/cfb_console.c:1765:18: error: 'bmp_logo_palette' undeclared (first use in this function)
logo_red[i] = (bmp_logo_palette[i] & 0x0f00) >> 4;
drivers/video/cfb_console.c:166:31: error: 'BMP_LOGO_OFFSET' undeclared (first use in this function)
#define VIDEO_LOGO_LUT_OFFSET BMP_LOGO_OFFSET
drivers/video/cfb_console.c:1778:22: note: in expansion of macro 'VIDEO_LOGO_LUT_OFFSET'
video_set_lut(i + VIDEO_LOGO_LUT_OFFSET,
drivers/video/cfb_console.c: In function 'video_logo':
drivers/video/cfb_console.c:181:24: note: in expansion of macro 'VIDEO_LOGO_WIDTH'
#define VIDEO_INFO_X (VIDEO_LOGO_WIDTH)
drivers/video/cfb_console.c:1911:32: note: in expansion of macro 'VIDEO_INFO_X'
space = (VIDEO_LINE_LEN / 2 - VIDEO_INFO_X) / VIDEO_FONT_WIDTH;
scripts/Makefile.build:280: recipe for target 'drivers/video/cfb_console.o' failed
make[2]: *** [drivers/video/cfb_console.o] Error 1
scripts/Makefile.build:425: recipe for target 'drivers/video' failed
make[1]: *** [drivers/video] Error 2
Makefile:1233: recipe for target 'drivers' failed
make: *** [drivers] Error 2
make: *** Waiting for unfinished jobs....
make: *** wait: No child processes. Stop.
The error is stated here:
ERROR: Input file is not a bitmap. What kind of image file did you use?
when i removed that toradex.bmp from that location /u-boot-toradex/tools/logos
Why did you delete this file? You have restore the original file from Toradex or replace with a proper one. This file must be proper bmp file as described here.
