I want to add restclient-cpp to the Linux 2.7b4 (morty branch) image to be used with Colibri iMX6.
I create a recipe using recipetool. The recipe generated is as follows:
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://LICENSE;md5=875d6e9ec1cb59099f4d9da1e81d1e91 \
file://vendor/gtest-1.7.0/LICENSE;md5=cbbd27594afd089daa160d3a16dd515a \
file://docs/_layouts/LICENSE;md5=46f112bee3cc17cf65f6e9fd31b713ea"
SRC_URI = "gitsm://github.com/mrtazz/restclient-cpp.git;protocol=https"
# Modify these as desired
PV = "1.0+git${SRCPV}"
SRCREV = "affecbf5d6ae64218f1fdab571c3805a1e1071cf"
S = "${WORKDIR}/git"
# NOTE: unable to map the following CMake package dependencies: jsoncpp GTest
DEPENDS = "curl"
inherit cmake
# Specify any options you want to pass to cmake using EXTRA_OECMAKE:
EXTRA_OECMAKE = ""
When I run bitbake restclient-cpp I get the following error
| CMake Error at CMakeLists.txt:2 (cmake_minimum_required):
| CMake 3.10.0 or higher is required. You are running version 3.6.1
| -- Configuring incomplete, errors occurred!
but when I inherit autotools along with cmake in the recipe, I get following error
| ERROR: oe_runmake failed
| fatal: Not a git repository (or any of the parent directories): .git
| m4 -I m4 -DM4_RESTCLIENT_VERSION= version.h.m4 > include/restclient-cpp/version.h
| /bin/sh: include/restclient-cpp/version.h: No such file or directory
| Makefile:1096: recipe for target 'include/restclient-cpp/version.h' failed
| make: *** [include/restclient-cpp/version.h] Error 1
| make: *** Waiting for unfinished jobs....
| ERROR: Function failed: do_compile
This is the file that gets generated when we do a make install for the git package.
Is there any way to get restclient-cpp installed without upgrading cmake to 3.10.0 ?
