Compatibility & pSLC Configuration 32GB to 64GB eMMC on Verdin i.MX8M Plus SoM
Hi Support Team,
We are currently using the Verdin i.MX8M Plus SoM with 32GB eMMC in our production setup. Due to supply chain lead times, If we are considering switching to the 64GB eMMC variant of the same SoM.
If we want to use 64GB SoM variant could you please clarify how the larger eMMC behaves and confirm the following technical aspects regarding software and pSLC configuration?
  1. Drop-in Software Compatibility: Will our existing U-Boot, Linux Kernel, Device Tree, and rootfs images built for the 32GB eMMC variant boot and run as-is on the 64GB eMMC variant without requiring any BSP or software modifications?
  2. Partitioning & Flashing (Toradex Easy Installer): If our image.json specifies fixed partition sizes tailored for the 32GB eMMC (treating the 64GB flash effectively like a 32GB device and leaving the remaining space unallocated), will Toradex Easy Installer flash it cleanly without errors?
  3. pSLC Mode Configuration & Behavior:
    • If we configure a region of the 64GB eMMC into pSLC mode (Enhanced User Area via mmc hwpartition) to match endurance or performance characteristics previously evaluated or required for our application, how does the underlying block allocation scale compared to a 32GB part? Is the same steps for 64GB to use pSLC mode?
    • Does configuring pSLC on the 64GB variant follow the exact same offset and size calculation logic in U-Boot/Linux mmc-utils, or are there block-addressing differences due to the increased density?
  4. Beyond the eMMC density, are there any eMMC vendor, timing, or hardware revision differences on the 64GB variant that could affect bootloader or kernel behavior?
Thank you for your support..!!
Vishal
Compatibility & pSLC Configuration: 32GB to 64GB eMMC on Verdin i.MX8M Plus
Hi Vishal,
To help you properly, I need to clarify which specific product variants you’re working with, as this significantly impacts the technical details.
Please Confirm Your Hardware Configuration
Could you specify:
  • Current 32GB variant PID8 (e.g., 00581100, 00631100, 00701100)?
  • Target 64GB variant PID8 (e.g., 02361100, 02371100)?
  • Which OS and version are you running (e.g., Torizon OS 6.8.0, BSP 7.x)?
You can use the tdx-info command on your module to get this information: Getting Device Information with Tdx-Info | Toradex Developer Center
General Guidance (Pending Your Specifics)
1. Software Compatibility
The 64GB variants are based on newer hardware revisions with specific eMMC changes. The revision history shows the 64GB variants (PID 0236 and 0237) use Kingston EMMC64G-IY29-5B101 instead of the Micron parts used in earlier 32GB versions(1). Software compatibility depends on whether your BSP/bootloader supports the new eMMC controller characteristics.
2. Partitioning Behavior
If your image.json specifies fixed partition sizes for 32GB, the remaining space on a 64GB module would be unallocated. However, I cannot confirm whether Toradex Easy Installer will handle this scenario without errors for your specific variant combination without knowing your exact hardware versions.
3. pSLC Configuration
For TLC eMMC (which the 32GB variants use), configuring Enhanced User Area follows this principle: the available enhanced area is approximately one-third of the total user data area(2)(3).
The configuration uses U-Boot’s mmc hwpartition command with block-aligned sizes based on the HC WP Group Size(3):
mmc hwpartition user enh <start_block> <block_count> wrrel on complete
(3)
The calculation must account for:
  • 512-byte block alignment
  • HC WP Group Size alignment (typically 8 MiB)
  • Maximum enhanced size limits reported by the eMMC(3)
For a 64GB variant, the same calculation logic applies, but the absolute block counts and maximum enhanced area size will scale proportionally.
4. Hardware Differences
The revision history indicates changes beyond just capacity, including different eMMC vendors and component assembly changes (e.g., C6, D4, R17 assembly status modifications)(1). These could potentially affect timing or initialization behavior.
Next Steps
Please provide your specific PID8 numbers and OS version so I can give you precise compatibility information and pSLC configuration guidance for your exact hardware combination.
Toradex AI Assistant
