Common_clk_si5341
I need to use the clock driver from COMMON_CLK_SI5341. Is this something that can be enabled in the Torizon kernel, or do I need to build my own?
I’d be glad to help with the SI5341 clock driver! To provide you with the most accurate guidance, could you let me know:
  1. Which hardware are you using? (e.g., Verdin i.MX8M Plus, Verdin AM62, Apalis i.MX8QP, Colibri i.MX8X)
  2. Which OS and version are you running? (e.g., Torizon OS 6, Torizon OS 7.2.0-build.13, BSP 7)
You can get detailed information about your system by running the tdx-info command on your device. More details are available at: Getting Device Information with Tdx-Info | Toradex Developer Center
Checking Driver Availability
Once I know your platform, I can help you check if the SI5341 driver is available. Similar to other kernel modules, you can check if COMMON_CLK_SI5341 is available in your current Torizon OS by running(1):
# zcat /proc/config.gz | grep SI5341
Available Options
Based on the documentation, if the driver isn’t available by default, you have several options(2):
  • Request inclusion: Ask Toradex to include it by default in future releases
  • External kernel module: Add it as an external kernel module via TorizonCore Builder(3)
  • Custom Yocto build: Build your own Torizon OS image with the driver enabled
The TorizonCore Builder approach for external kernel modules is well-documented and allows you to build kernel modules from source and deploy them to your Torizon OS system(3).
Common platforms include:
  • Hardware: Verdin i.MX8M Plus, Verdin AM62, Aquila AM69, Apalis i.MX8QP, Colibri i.MX8X
  • OS: Torizon OS 6, Torizon OS 7.2.0-build.13, BSP 7, BSP 6
Verdin i.MX8M Plus And Torizon 7
Check Driver Availability First
For the Verdin iMX8M Plus with Torizon OS 7, first check if the COMMON_CLK_SI5341 driver is already available in your current kernel configuration(1):
If the configuration shows CONFIG_COMMON_CLK_SI5341=m, then the driver is available as a Loadable Kernel Module (LKM) and you can activate it using a Device Tree Overlay(1).
If Driver is Not Available
If the driver is not available in your current Torizon OS 7 image, you have several options:
Option 1: Build External Kernel Module
Follow the instructions in the Building External Kernel Modules With Torizon article to add the SI5341 driver as an external module(1).
Option 2: Custom Torizon OS Image
You can build a custom Torizon OS image with the driver enabled. For the Verdin iMX8M Plus, you would need to clone the appropriate kernel source(2):
git clone -b toradex_6.6-2.2.x-imx git://git.toradex.com/linux-toradex.git linux
Then customize the kernel configuration to include CONFIG_COMMON_CLK_SI5341=m and build your custom image.
Device Tree Integration
Once the driver is available, you’ll need to create a Device Tree Overlay to configure the SI5341 clock generator on your I2C bus. The process is similar to other I2C devices - you’ll need to identify the correct I2C bus and create an overlay that configures the si5341 node(1).
For the Verdin iMX8M Plus, you can use the general-purpose I2C buses like I2C4 (accessible via verdin-i2c1)(1).
Greetings @kdubious,
Just to confirm, since you marked the AI’s response as a solution. Which option forward are you going with?
I ended up in a spot where patching the driver was a valid patch forward for me. At that point, it seemed best just to pull the driver code out, edit it as I needed, and build that as a module.
patching the driver
If your use-case requires the patching of this existing driver, then this makes sense. Thanks for confirming just wanted to understand what solution you ended up going with.
