Is possible change LUTs for RGB channel on Colibri T20 ?
What tool allows change color profile ?
I have new supplier of LCD panels, and some other colors
I would like to correct this on the operating system side
Hi @MariusM ,
Thanks for the question. I’ll have some chats internally about that and will come back to you.
Kevin
Linux BSP 2.x
Hi @MariusM ,
I assume you would like to adapt the color of your UI background and certain UI elements am I right?
As far as I know it is not possible to change single RGB values. What should be possible though is that you use an 8bit palette framebuffer in which you would be able to define 256 colors. I’m still searching for documentation that describes this process. As soon as I have found that I will let you know.
Kevin
Hi @MariusM ,
Thanks for the test images. The last picture of yours, how did you achieve the correction?
Kevin
