This post is a follow-up to the post:
I have another PXA270 module that I wanted to re-flash the image through ColibriLoader and Ethernet, but I get the following error:
[upload|fct5xnYLPE7RoGf0xeDt/gWEBXI=]
[upload|vE8IfrrR4glbg9z0WX9QRMwXPss=]
How should I resolve this?
Dear @shiva_eghbal
This sounds like some kind of Ethernet problem.
- Try to disable any firewall and/or virus scanners
- Is it possible that the subnet mask is setup in a way that the PC
and Colibri are in different subnets?
The IP adresses are close, so I think
it is all fine, but please check
anyway.
- Can you try to use a different PC, or connect PC and Evalboard to a
different network?
- How about just replacing the Colibri, otherwise keep all settings
unchanged. Does this also generate an
error?
Regards, Andy
I tried it again and this time it worked.
However now my application doesn’t run. What might cause that?
Dear @shiva_eghbal
Please open a new question for this new issue, and add some more details to explain what happens.
Regards, Andy
