Colibri VF61 - Viola 1.1 Bootloader not working
Hello everyone, this is my first post. My language is brazilian portuguese, so my english is not very good, but I’ll try to do my best :slight_smile:
So, my problem is that when I started the module for the first time, I asked my friend to stay pressing the space key and when the module has been started, it’s started an unexpected procedure, instead showing a menu. Then I stopped the module and when I rebooted, it showed this message and the space key not worked.
Toradex Bootloader 1.1 BETA 2 for Colibri Built Apr 28 2015
CPU: MVF61 500 Mhz
Flash: 512 MB
RAM: 256 MB
Using ECC Type: 7
Booting from fuses.
Colibri VF61 module version 1.1B
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 0 seconds.
Loading OS Image
Loading 21015156 bytes to RAM.
Done.
OEMLaunch 80004000
Please help me!
Thanks!
This bootloader is to old to do any tests. Please download latest version VF50 / VF61 WEC Software | Toradex Developer Center
And use recovery mode to flash new loader → VFxx Recovery Mode | Toradex Developer Center
I want to install the embedded linux instead of windows CE. How can I do it without re-flashing an newer windows CE version?
Here are instructions on how to use recovery mode to install linux
