Our company received new Colibri VF61 boards V1.2B. Our previous Colibri boards were V1.2A.
We use WinCE 6 image with 1.4 version and flash image and bootloader using update.exe utility. And now we have a problem with V1.2B boards - after flashing image and bootloader V1.4 the board is bricked:
Splash screen is not saved in flash.
Toradex Bootloader 1.4 for Colibri Built Mar 30 2017
CPU: MVF61 500 Mhz
Flash: 1024 MB
RAM: 256 MB
Using ECC Type: 7
Booting from fuses.
FCB is not valid!
FCB sector is not empty, restore failed!
Config block is empty, restoring it using static config block data.
Invalid temp static config block checksum on byte 0
Error restoring config block.
Colibri VF61 module version 1.2B
Press [SPACE] to enter Bootloader Menu
Initiating image launch in 0 seconds.
Loading OS Image
Error reading OS Image from flash
Is there some problem with compatibility of new boards and image v1.4?
