Flash Health Monitoring on Colibri VF61
The Colibri VF61 uses 512MB NAND (8 Bit) raw NAND flash memory (1), which requires specific approaches for health monitoring compared to eMMC-based modules.
Flash Memory Type on VF61
The Colibri VF61 features Raw NAND (SLC) flash storage (2). Unlike eMMC devices that have built-in controllers providing standardized health metrics, raw NAND requires different monitoring approaches (2).
MTD-Utils for Raw NAND Health Monitoring
For raw NAND devices like the VF61, mtd-utils is indeed the primary tool for flash health assessment. Here are the key commands:
1. Bad Block Information
mtd_debug info /dev/mtdX
(2)
This command provides basic information about the MTD device, including bad block counts.
2. Bad Block Scanning
nandtest /dev/mtdX
(2)
This performs a comprehensive test of the NAND flash, identifying bad blocks and potential issues.
Understanding the Output
When using these tools, look for:
- Bad block count: Higher numbers indicate flash wear (2)
- ECC errors: Error correction events that suggest degrading flash health (2)
- Write/erase cycle estimates: Though not directly provided, can be inferred from bad block progression (2)
Flash Health Considerations for VF61
Endurance Characteristics
The VF61 uses SLC NAND, which provides (3):
- Highest endurance compared to MLC/TLC
- Highest lifetime
- Highest performance
- High cost per capacity
SLC NAND typically supports around 100K erase cycles (2), significantly higher than MLC flash.
Write Amplification Impact
Be aware that flash cannot be rewritten without being erased first, and this must be done at the erase block level (up to 512 KB) (2). This write amplification effect means writing small amounts of data can trigger larger erase operations (2).
Alternative Monitoring Methods
Besides mtd-utils, you can monitor flash health through:
1. UBI Statistics
Since the VF61 uses UBI/UBIFS filesystem (2), you can check:
cat /sys/class/ubi/ubi0/*/bad_peb_count
2. Kernel Log Monitoring
Monitor dmesg output for:
- UBI error messages
- Bad block notifications
- ECC correction events
3. Filesystem-Level Monitoring
Monitor write patterns and frequency to estimate wear based on your application’s usage patterns (2).
Best Practices for Flash Health
- Minimize write operations to extend flash life (2)
- Monitor write behavior of your application (2)
- Run stress tests to validate flash endurance for your use case (2)
- Avoid using full capacity to improve wear leveling efficiency (2)
Important Note
Unlike eMMC devices that provide standardized health metrics (as shown in TorizonCore with mmc-utils (4)), raw NAND devices like the VF61 require more manual monitoring approaches using MTD utilities and system-level observation.
The VF61’s SLC NAND provides excellent endurance characteristics, but proper monitoring using mtd-utils and system observation remains essential for long-term reliability assessment.
