We’re facing issues using the UART on the Colibri-IMX8X.
We use a custom carrierboard which connects all 3 UARTs to different RS-485 transeivers.
(In production, a baudrate of 38400 is used, I tested with 115200, but there isn’t a big difference when changing it, regarding this problem).
We don’t use RTS/CTS functionality on the UART and we don’t configure it as RS-485, this part is handled by some logic on the board directly.
When reading from the UART-A and UART-C (ttyLP3 and ttyLP2), it takes very long (~130ms) for the read() function to return data. On UART-B (ttyLP0) this is not an issue, latency is much better here (around 10ms).
On the RS-485, I have a test device that sends out the following data with a delay of ~10ms in alternating order and 1 byte counting up each time:
uint8_t Msg1[] = {0x08, 0x00, 0x00, 0x64, 0x02, 0x10, 0x11, **counter**};
uint8_t Msg2[] = {0x1B, 0x30, 0x00, 0x00, 0x65, 0x05, 0x31, **counter**, 0x32, 0x33, 0x34, 0x35, 0x36};
Generally, on the positve side, there’s no data lost on all uarts, but the read delay of 130ms is too long for our application.
There’s no other load on the system that would cause an influence that high.
I wrote some test code (see below), so others here might be able to reproduce this.
Result for UART-A+C:
Console:
main:272 (6): recvd 126 bytes
main:274 (6): read() took t1->t2=131856us
main:274 (6): read() took t1->t2=131798us
main:272 (6): recvd 127 bytes
main:274 (6): read() took t1->t2=142043us
main:272 (6): recvd 133 bytes
main:274 (6): read() took t1->t2=132169us
main:274 (6): read() took t1->t2=131828us
main:274 (6): read() took t1->t2=131837us
main:274 (6): read() took t1->t2=142492us
main:272 (6): recvd 128 bytes
main:274 (6): read() took t1->t2=132014us
main:274 (6): read() took t1->t2=132020us
main:272 (6): recvd 134 bytes
main:274 (6): read() took t1->t2=132265us
I also made some tests with an oscilloscope to verify that my measurements are correct, just using a Pin as a trigger signal (Yellow: Trigger pin, low after read, Blue: RS485 data).
As you can see, the delay is indeed very high and corresponds with the measured delay in software.
Result for UART-B:
Console:
main:274 (6): read() took t1->t2=10952us
main:272 (6): recvd 5 bytes
main:274 (6): read() took t1->t2=757us
main:272 (6): recvd 8 bytes
main:274 (6): read() took t1->t2=10181us
main:274 (6): read() took t1->t2=10965us
main:274 (6): read() took t1->t2=758us
main:274 (6): read() took t1->t2=10187us
main:274 (6): read() took t1->t2=10953us
main:274 (6): read() took t1->t2=752us
main:274 (6): read() took t1->t2=10956us
main:274 (6): read() took t1->t2=756us
main:274 (6): read() took t1->t2=10193us
main:274 (6): read() took t1->t2=10958us
Here the trace with the oscilloscope (Yellow: Trigger pin, low after read, Blue: RS485 data)
And some closer lookup, you can see the data is read quite quickly as soon as it is received (~700-800us after receiving the first bit):
The 10ms are because of the send delay of the test-device on the bus (see above). So this port works without issues.
Here’s my test code, compile it using the sdk (or on the target, if build tools are installed).
serial-test-minimal.c:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#include <inttypes.h>
#include <time.h>
#include <unistd.h>
#include <poll.h>
#include <fcntl.h>
#include <termios.h>
#include <linux/serial.h>
#include <sys/ioctl.h>
//#define USE_GPIOLIB_FOR_TRIGGER
#ifdef USE_GPIOLIB_FOR_TRIGGER
#include "noxgpio.h"
#include "nox_global.h"
#include "nox_internal.h"
#define GPIO_TRIGGER(f_High) noxGPIO_SetDO_NXB3TxDisable(f_High)
#else
#define LOG_TEXT(prio,txt,...) printf("%s:%d (%d): " txt "\n",__func__,__LINE__,prio,##__VA_ARGS__)
enum ReturnCodes
/* General error return values */
ERR_NONE =0, /* No error, success */
ERR_NOT_INITIALISED =-1, /* Unit has not been initialised */
ERR_INVALID_PARAM =-2, /* Invalid paremeter passed to function */
ERR_BUF_TOO_SMALL =-3, /* Buffer is too small to hold the result */
ERR_NONMEM =-4, /* Failed to allocate memory */
ERR_IO =-5, /* Some Error happened performing I/O operations */
ERR_PERMISSION =-6, /* Couldn't access ressource/perform action because permissions */
ERR_NOT_AVAILABLE =-7, /* Ressource is not available (e.g. GPIO pins on some board revisions) */
ERR_IPC_PROTOCOL_USAGE =-10, /* IPC command failed due to invalid format (see nox_ipc_global.h) */
ERR_IPC_COMMAND_EXECUTION =-11, /* IPC command failed to execute (see nox_ipc_global.h) */
ERR_INTERNAL =-100,/* Internal error, see syslog */
enum
LOG_EMERG=0,
LOG_ALERT,
LOG_CRIT,
LOG_ERR,
LOG_WARNING,
LOG_NOTICE,
LOG_INFO,
LOG_DEBUG
#endif
typedef enum
SBAUD_9600=9600,
SBAUD_19200=19200,
SBAUD_38400=38400,
SBAUD_115200=115200,
}serial_baudrate;
typedef struct
serial_baudrate baudrate;
}serialport_settings_t;
int32_t serialport_open(const char *path,
serialport_settings_t *settings,
void **fd_ptr)
int tmp;
int fd;
struct termios options;
switch(settings->baudrate)
case SBAUD_9600:
tmp=B9600;
break;
case SBAUD_19200:
tmp=B19200;
break;
case SBAUD_38400:
tmp=B38400;
break;
case SBAUD_115200:
tmp=B115200;
break;
default:
LOG_TEXT(LOG_ERR,"Invalid/Unimplemented baudrate=%d",settings->baudrate);
return(ERR_INTERNAL);
if((fd=open(path, O_RDWR | O_NDELAY | O_NOCTTY)) < 0)
LOG_TEXT(LOG_ERR,"open() failed (%d): %s",errno,strerror(errno));
return(ERR_IO);
if(tcgetattr(fd, &options) == -1)
LOG_TEXT(LOG_ERR,"tcgetattr() failed (%d): %s",errno,strerror(errno));
close(fd);
return(ERR_IO);
options.c_cflag=tmp | CS8 | CLOCAL | CREAD;
options.c_iflag=IGNPAR | IGNBRK;
options.c_oflag=0;
options.c_lflag=0;
options.c_cc[VTIME]=0;
options.c_cc[VMIN]=1;
if(tcsetattr(fd, TCSANOW, &options) == -1)
LOG_TEXT(LOG_ERR,"tcsetattr() failed (%d): %s",errno,strerror(errno));
close(fd);
return(ERR_IO);
/* Apply the settings */
if(tcflush(fd, TCIFLUSH) == -1)
LOG_TEXT(LOG_ERR,"tcflush() failed (%d): %s",errno,strerror(errno));
close(fd);
return(ERR_IO);
/* Set blocking mode */
if(fcntl(fd, F_SETFL, 0) == -1)
LOG_TEXT(LOG_ERR,"fcntl() failed (%d): %s",errno,strerror(errno));
close(fd);
return(ERR_IO);
struct serial_struct serial={0};
if(ioctl(fd, TIOCGSERIAL, &serial) == -1)
LOG_TEXT(LOG_ERR,"ioctl() failed (%d): %s",errno,strerror(errno));
close(fd);
return(ERR_IO);
LOG_TEXT(LOG_DEBUG,"type=%d Recvbuf=%d flags=%X",serial.type,serial.xmit_fifo_size,serial.flags);
*((intptr_t**)fd_ptr)=(intptr_t*)fd;
return(ERR_NONE);
void serialport_close(void *fd)
close((intptr_t)fd);
int32_t serialport_read(void *fd,
uint8_t *buf,
uint32_t bufLen)
ssize_t tmp=bufLen;
if((!fd) || (!buf) || (!bufLen))
return(ERR_INVALID_PARAM);
if(bufLen > INT32_MAX)
LOG_TEXT(LOG_ERR,"bufLen too big, is=%u, max=%d",bufLen,INT32_MAX);
tmp=read((int)fd,(void*)buf,tmp);
if(tmp == -1)
LOG_TEXT(LOG_ERR,"read() failed (%d): %s",errno,strerror(errno));
return(ERR_IO);
return(tmp);
uint64_t difftimeUs(const struct timespec *start, const struct timespec *end)
// Calculate the difference in seconds and nanoseconds
long seconds = end->tv_sec - start->tv_sec;
long nanoseconds = end->tv_nsec - start->tv_nsec;
// Convert the total difference into milliseconds
uint64_t microseconds = (uint64_t)(seconds * 1000000) + (nanoseconds / 1000);
// Return the absolute value of the difference
return(microseconds);
int main()
int32_t ret;
void *pHandle;
serialport_settings_t serial_settings;
const char *serial_path="/dev/ttyLP0"; /* Change port here and recompile for testing */
uint8_t rdBuf[512];
struct timespec t1, t2;
uint32_t totalLen;
serial_settings.baudrate=SBAUD_115200;
uint32_t options=OPT_LOG_LEVEL_STDOUT_INFO;
if((ret=initInternal(options,NULL,"serialport-test")) != ERR_NONE)
fprintf(stderr,"initInternal() failed (%d)\n",ret);
return(EXIT_FAILURE);
if((ret=noxGPIO_InitLib(options,"serialport-test")) != ERR_NONE)
fprintf(stderr,"noxGPIO_InitLib() failed (%d)\n",ret);
#endif
GPIO_TRIGGER(0);
if((ret=serialport_open(serial_path,&serial_settings,&pHandle)) != ERR_NONE)
LOG_TEXT(LOG_ERR,"serialport_open() failed: %d",ret);
clock_getres(CLOCK_MONOTONIC_RAW,&t1);
LOG_TEXT(LOG_INFO,"Clock resolution: %ld ns",t1.tv_nsec);
totalLen=0;
while(1)
clock_gettime(CLOCK_MONOTONIC_RAW,&t1);
GPIO_TRIGGER(1);
if((ret=serialport_read(pHandle,
&rdBuf[totalLen],
sizeof(rdBuf) - totalLen - 1)) < 0)
LOG_TEXT(LOG_ERR,"serialport_read() failed: %d",ret);
clock_gettime(CLOCK_MONOTONIC_RAW,&t2);
GPIO_TRIGGER(0);
totalLen=0;
LOG_TEXT(LOG_INFO,"recvd %d bytes",ret);
LOG_TEXT(LOG_INFO,
"read() took t1->t2=%" PRIu64 "us",
difftimeUs(&t1,&t2));
serialport_close(pHandle);
return(EXIT_SUCCESS);
Is this a known issue? How can we fix this?
System info:
Colibri IMX8X with BSP 7.0
If you need more information, please let me know.
Thanks and regards
Simon
