Hello.
I’m supporting a legacy product running Windows CE 8.0 on Colibri T30.
The product runs a C# application interfacing the legacy Windows CE libraries.
We are aware that all this stuff is deprecated years ago and are in the process of developing new Linux based solutions…
Anyways, we are facing an issue where an increasing amount of customers are reporting random system freezes that can only be resolved by rebooting the device (power cycling).
We have quite randomly managed to reproduce the issue…
The serial debug interface does not provide anything between our last application random logging entry and the freeze, drWatson also does not generate any file in this case.
The application uses stuff like CAN, Ethernet and such. The hardware watchdog is disabled, currently its not feasible to have the system reboot.
Currently our main root cause suspects are:
1
WC-1747: “Threads with higher priority (<101) can freeze the device”.
- We dont explicitly force any of our threads to run on core 1, however in most cases everything just runs on core 1.
- We dont explicitly start any threads with such high priority.
However, when examining the application process using the task manager, we observe a thread with priority “001” the average cpu load of the thread is close to 0.01%. I suspect the thread could be spawned by a (legacy) driver?
Can you confirm if this is the case and if its possible that this could be the root cause?
2
Since the application uses the legacy Windows CE libraries I had a look at the release notes for the newer libaries (the single api/dll one) and stumbled across:
WCL-1194: “Re-Initializing CAN Library could freeze the system”.
- The CAN communication to the slave device can sometimes timeout, etc. so that we may re-initialize the can library.
However since we are using the legacy libraries (SJA1000 v3.3.2) we want to have some clarification as to if this issue is relevant for that library?
We are unable to make the system freeze by forcing a lot of CAN re-inits…
Thanks in advance for taking the time to provide feedback. As i mentioned, we are aware that the solutions used in this product was deprecated years ago…
My user does not have file upload permissions so here goes the boot up dbg log:
"“6/25/2024 3:13:28 PM”, Toradex Bootloader 2.4b2 for Tegra Built Feb 16 2020 16:19:11
“6/25/2024 3:13:29 PM”,Press [SPACE] to enter Bootloader Menu
“6/25/2024 3:13:29 PM”,Colibri T30 1GB 1.1G Serial: 7281994
“6/25/2024 3:13:29 PM”,RAM: 1024 MB, CarveOut: 2 MB
“6/25/2024 3:13:29 PM”,Loading IM1 image from flash…Done(279ms)
“6/25/2024 3:13:29 PM”,Checking Image CRC…OK(60ms)
“6/25/2024 3:13:29 PM”,Decompressing IMAGE(25100684, 42310380) from 8286FB00 to 80016000…Done(368ms)
“6/25/2024 3:13:30 PM”,Jumping to image at 0x80016000…
“6/25/2024 3:13:30 PM”,Toradex Windows CE 8.0 2.4b2 for Tegra Built Feb 16 2020 16:10:21
“6/25/2024 3:13:30 PM”,INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0xb
“6/25/2024 3:13:30 PM”,L2 cache enabled
“6/25/2024 3:13:30 PM”,MainMemoryEndAddress adjusted from 0x9F000000 to 0x9FE00000
“6/25/2024 3:13:30 PM”,Main Phys Mem: 0x80000000:0x9FDFFFFF
“6/25/2024 3:13:30 PM”,Carveout Phys: 0x9FE00000:0x9FFFFFFF
“6/25/2024 3:13:30 PM”,Cold boot selected
“6/25/2024 3:13:30 PM”,SMP: Active CPUs = 4
“6/25/2024 3:13:30 PM”,Extended Mem : 0xA0000000:0xBFFFFFFF
“6/25/2024 3:13:30 PM”,Chip Id: 0x30 (Handheld SOC) Major: 0x1 Minor: 0x3 SKU: 0xb1
“6/25/2024 3:13:30 PM”,ATE prog ver 4.0
“6/25/2024 3:13:30 PM”,Speedo: CPU: 354 (Corner: 1), Core: 216 (Corner: 0)
“6/25/2024 3:13:30 PM”,NVRM Initialized shmoo database
“6/25/2024 3:13:30 PM”,PllClocks(Mhz): X=1300, M=800, C=600, P=408, A=24.576
“6/25/2024 3:13:30 PM”,SysClocks(Mhz): CPU=1300, AVP=240, SysBus=240, Mem=400, EMem=800
“6/25/2024 3:13:30 PM”,GraphicClocks(Mhz): Host=133, 3D=133, 2D=133, Epp=133, Mpe=133, Vde=408
“6/25/2024 3:13:30 PM”,Loading ResourceManager…
“6/25/2024 3:13:30 PM”,Load_Init_Syncpoint_Values:
“6/25/2024 3:13:30 PM”,Done Loading ResourceManager (3 ms)
“6/25/2024 3:13:30 PM”,Loading FlashFileSystem(NAND)…
“6/25/2024 3:13:30 PM”,Failed(0) Loading FlashFileSystem(NAND) (0 ms)
“6/25/2024 3:13:30 PM”,Loading FlashFileSystem(eMMC)…
“6/25/2024 3:13:30 PM”,Done Loading FlashFileSystem(eMMC) (0 ms)
“6/25/2024 3:13:30 PM”,Waiting for flash disk \FlashDisk for 300 seconds
“6/25/2024 3:13:30 PM”,Folder mounted
“6/25/2024 3:13:30 PM”,Loading MultimediaManager…
“6/25/2024 3:13:30 PM”,Done Loading MultimediaManager (0 ms)
“6/25/2024 3:13:30 PM”,Loading Audio…
“6/25/2024 3:13:30 PM”,Loading Serial3…
“6/25/2024 3:13:30 PM”,Done Loading Serial3 (1 ms)
“6/25/2024 3:13:30 PM”,Loading Serial2…
“6/25/2024 3:13:30 PM”,Loading Serial1…
“6/25/2024 3:13:30 PM”,Done Loading Serial2 (1 ms)
“6/25/2024 3:13:30 PM”,Failed(0) Loading Serial1 (0 ms)
“6/25/2024 3:13:30 PM”,Loading SDIO…
“6/25/2024 3:13:30 PM”,Done Loading SDIO (5 ms)
“6/25/2024 3:13:30 PM”,Loading USBOTG(Port1)…
“6/25/2024 3:13:30 PM”,Loading USBHost(Port3)…
“6/25/2024 3:13:30 PM”,Loading USBHost(Port2)…
“6/25/2024 3:13:30 PM”,Done Loading USBOTG(Port1) (5 ms)
“6/25/2024 3:13:30 PM”,VBUS=0, ID=0
“6/25/2024 3:13:30 PM”,ChangeMode(0, 2)
“6/25/2024 3:13:30 PM”,OTG(0): Loading HCD…
“6/25/2024 3:13:30 PM”,SDHCDIndicateSlotStateChange(DeviceInserted)
“6/25/2024 3:13:30 PM”,Loading USBHost(Port1)…
“6/25/2024 3:13:30 PM”,Loading DisplayDriver…
“6/25/2024 3:13:30 PM”,Done Loading DisplayDriver (37 ms)
“6/25/2024 3:13:30 PM”,Set LCD to 800x480 (51Hz)
“6/25/2024 3:13:30 PM”,Set HDMI to 800x480 (60Hz)
“6/25/2024 3:13:30 PM”,Done Loading USBHost(Port3) (198 ms)
“6/25/2024 3:13:30 PM”,Loading Keyboard/MouseDriver…
“6/25/2024 3:13:31 PM”,Done Loading Keyboard/MouseDriver
“6/25/2024 3:13:31 PM”,NvDdkSdioSetClockFrequency: Requested: 100 KHz, Actual: 100 KHz
“6/25/2024 3:13:31 PM”,Loading TouchDriver…
“6/25/2024 3:13:31 PM”,Maximum Allowed Error 5:
“6/25/2024 3:13:31 PM”,Done Loading TouchDriver
“6/25/2024 3:13:31 PM”,Done Loading Audio (346 ms)
“6/25/2024 3:13:31 PM”,SoftRTC enabled
“6/25/2024 3:13:31 PM”,Done Loading USBHost(Port2) (336 ms)
“6/25/2024 3:13:31 PM”,Done Loading USBHost(Port1) (452 ms)
“6/25/2024 3:13:31 PM”,OTG(0) Done Loading HCD
“6/25/2024 3:13:31 PM”,No external RTC found
“6/25/2024 3:13:32 PM”,Loading NETUI…
“6/25/2024 3:13:32 PM”,Done NETUI
“6/25/2024 3:13:32 PM”,AX88772B: instantiate [AX88772B1]
“6/25/2024 3:13:36 PM”,AX88772B: MediaChange()
“6/25/2024 3:13:39 PM”,AX88772B: MediaChange()
“6/25/2024 3:13:41 PM”,AX88772B: MediaChange()
“6/25/2024 3:14:38 PM”,Using CANLib Version 3.3.2
“6/25/2024 3:14:38 PM”,Using IntLib Version 2.6.0
“6/25/2024 3:14:38 PM”,Using ClkLib Version 3.3.0
“6/25/2024 3:14:38 PM”,Message Buffer created. Size 100 Messages Physical Address 0xbb85c000
“6/25/2024 3:14:38 PM”,Starting IST:"
