Hello support.
I had one Colibri T30 board purchased back in 2016 and never used. I decided to set up a WEC2013 image on it and used nvFlash tool for that purpose.
During attempt to load up the image I got this ERROR message about missing serial number of board (taken from log):
Nvflash version 2.6 started
rcm version 0X30001
System Information:
chip name: unknown
chip id: 0x30 major: 1 minor: 3
chip sku: 0xb1
chip uid: 0x0000000000000000015d4b337534240f
macrovision: disabled
hdcp: enabled
jtag: enabled
sbk burned: false
dk burned: false
boot device: emmc
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
Sending generated BCT...533Mhz Done
downloading bootloader -- load address: 0x88300000 entry point: 0x88300000
sending file: loader.nb0
- 65536/467360 bytes sent
\ 467360/467360 bytes sent
loader.nb0 sent successfully
waiting for bootloader to initialize
bootloader downloaded successfully
ERROR: SerialNumber or ProductID lost
Please enter(or scan) the 16 digit barcode label data:
I had no 16 digit code on the back of my T30 board, only Windows license number which obviously did not work. Accidentally I took a 16 digit number from my other board which is Apalis T30 (different form factor) and entered it manually. I used this serial: 0025110102927621 ← Apalis T30.
I got my flasher to work well and flashed WEC2013 on this Colibri T30 board.
Now my board does not work and when boots in debug messages I see that it is recognized as Apalis T30 which obviously has different pinout etc.
How to reset my Colibri T30 back to state with no serial or whatever (delete config) ?
How to restore back functionality and most important where to get Serial number of my Colibri board ?
Please help.
Thanks,
Vlad
